Send a message via AIM to 82SC
how easily should my engine turn (manually)
while I was timing my cams I found that I had "bumps" as i turned the crank...
I would add a little more tension to the belt and it would go over the "hump"
is this normal??? or should it turn completely smoothly throughout the cycle??
I don't know if it is a rocker going over a cam lobe or is I am making contact with the piston...i triple checked my timing and I octaple check my valve adjustment...
thanks
MJ
Old 03-11-2003, 01:57 PM
McDaniel's Avatar
Plugs in or out?
Impotence...Nature's way of saying "No hard feelings."
McDaniel
1974 911 Targa
1995 Toyota Avalon
2004 Toyota Tundra Extended Cab
Old 03-11-2003, 02:05 PM
Paul Thomas's Avatar
Are your spark plugs in or out? If they are in, you are basically fighting compression on each stroke and the "bumps" are normal. The motor will rotate easier with the plugs out because the air has somewhere to go on the compression stroke. Even if they are out, you will not have a smooth, constant pressure while turning.
Paul
plugs in...I guess this answers my question
thanks guys
MJ
Old 03-11-2003, 02:21 PM
