Cht sensor
i HAVE 1984 3.2 CARERRA.
Trying to get the CHT sensor out of the head.
Soaked it in wd40 still wont move,
Scared to put to much pressure on it just in case it snaps or strips the thread.
Does any know if it is easy or not to snap or strip the thread. or am i ok to put more pressure on undoing it.
Old 12-19-2018, 10:44 AM
If it is the original CHT from 1984 is has been in there a long time. Cut the wire, and use a full socket with a quality tight fit. Not some cheap Chinese socket. It will come loose with a pop. You will need a CHT socket to get the new one seated properly. Or cut a long slot in a cheap Chinese socket.
Old 12-19-2018, 11:05 AM
I have cut the wire off.And got a socket on it just scared case i snap it or strip the thread
Old 12-19-2018, 11:14 AM
smokintr6's Avatar
Send a message via AIM to smokintr6
I think all the heads have a provision for a CHT, right? I'm not suggesting it would be desirable, but if yours breaks off, or strips the threads out, it wouldn't be the end of the world to wire in to a different location. It's been a minute since I've looked at the heads though (thankfully, knocks on wood)
Old 12-19-2018, 01:08 PM
DanielDudley's Avatar
Put the socket on it and remove it with authority.
CHT sensor snapped off in head
Old 12-19-2018, 01:25 PM
smokintr6's Avatar
That’s how I wish I would have treated my ex wife...
Old 12-19-2018, 02:11 PM
Cht sensor
If worst comes to worst and i have to drill it out,Does any one know is it a blind hole or does it go though to some where.
Old 12-19-2018, 03:31 PM
smokintr6's Avatar
I’m pretty sure it’s blind, going from memory... look at the holes on all the other heads, should be able to see exactly what you’re working with
Old 12-19-2018, 04:43 PM
Brap
tmaull's Avatar
I’d at least try some pb blaster for a few days.
Old 12-19-2018, 05:16 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
PB Blaster.
Yup!!!!!
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-19-2018, 05:41 PM
