Wait a minute. How the heck are you supposed to jumpstart a 911 ?
I've never jumpstarted my 911.
If the battery went dead, I'd just connect a battery charger. My charger has tiny little clamps, and I never thought much of it. Now, I own one of those jump packs. ![]() I tried to use it today. There is no way the full size clamps could fit down under the fender. Which begs the question, how the heck have you ever jumpstarted with jumper cables and clamps???? There is absolutely no room down there to fit a large red clamp.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 12-24-2018 at 04:24 PM.. |
I am now noticing the different batteries have the posts on different sides.
Contrast these two. The Bosch would have the red post on the INSIDE of the car, away from the fender. Ther other would have the red post on the OUTSIDE of the car, under the fender.
1986 Bosch Icon Wipers coupe. |
Lay the clamp down and slide it on. Or lock a pair of vice grips on the battery clamp and clamp the jumper to it. Use your imagination.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Eggzacery, or pull the battery, connect the cables, vroom, vroom.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Easier to push start!
Tony 1973 914 2.2 FAT Black 1974 911 Targa Lime Green 2018 Macan GTS White 2019 Targa GTS Agate Grey |
PCA, POC & SCCA long time Member |
I tried every angle, obviously. I love the Vice grip idea ! Quote:
There is no slack in the cables to stay connected to the battery. So, when you say "pull the battery", am I jump starting the naked battery cables with the unattached battery sitting on the ground? Can a car run without a battery attached? Do you reattach the battery to the cables while the car is running?
you will fry the alternator if you run the car without a battery. Are the cables so short you cannot slide the battery forward? It does not look like the terminals are correct for a Porsche, they should be on the other side. If the car can move a push start in 3d gear with ignition on is very easy.
Or put a charger on the battery and start it after its charged.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
As on many of my cars and motorcycles , I just add a jump wire to the + post and pull it into service when needed
Merry Christmas
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Keep a small needlenose visegrip in your tool kit. Clamp it on the + terminal clamp and attach the jumper to the visegrip.
I bought one of these for every car, Porsche and non-Porsche. Works great.
TOPDC Jumper Cables with Quick Plug 1 Gauge 25 Feet 700Amp Heavy Duty Booster Cables (1AWG...) For now mine are hooked up to the battery up front. When I re-wire the charging cables and cables to the starter motor the plug will be connected to the starter motor and the plug in the engine compartment. Merry Christmas to all, and too all good jumping!
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles Last edited by Duc Hunter; 12-25-2018 at 08:47 AM.. |
Troll Hunter
There's a thread on how to jump a 911? Now I've seen it all in the Tech Section.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Then put the negative on the bolt above.
What me speed? |
Good grief Sugar. Is everything in your life difficult?
Derrick |
Super easy to push start. Just like a bug!
scumbag
this is brilliant and exactly the kind of thing that would make jumping (or charging) a 911 super easy.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
I'm good with tools.
My charger has a quick connect.... most do. I also have a long lead with typical battery charging clamps to jump the car if necessary.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
