Banned
re-curve bosch distributor
hi all
was wondering if its possible to change the distributor advance curve, its a 0 231 159 008. which i beleve is a T dizzy
the reason i am asking is my motor is no longer a T.
S, pistons, ports, L cams ect
its a 71, 911 2.2
anyone ever tryed this?
are there companys that i can send it to?
Kyle
71 911
Old 03-11-2003, 06:27 PM
dtw dtw is offline
GAFB
*bump* i wanna know too
Several BMWs
Old 03-11-2003, 08:07 PM
Call Steve at Rennsport Sys. Or Andial
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-11-2003, 09:08 PM
Bird. It's the word...
Fishcop's Avatar
This is totally do-able.
I recently had a Bosch 2.7 carerra dizzy re-mapped to replace my 69T Marelli dizzy. But sorry no recommendation to you (I'm in Australia).
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-11-2003, 10:21 PM
Cool Re: re-curve bosch distributor
I bought a 2.7 RS dizzy for a carb install.. it was cheap/new.. I can probably find a shop that BA recommended if you are definately going to re-curve
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-11-2003, 10:40 PM
I forgot to say that if you have a timing light and can take apart a dist. you can do it yourself. You just need an assortment of springs.
Dean
Old 03-12-2003, 05:35 AM
jluetjen's Avatar
...You just need an assortment of springs.
You can often get a good supply of springs from your local speed shop. You will also potentially need something like a dremel moto-tool in case you need to increase the advance travel, and some way to fill in the slots if needed. I've considered using some sort of permenant epoxy or having slots soldered, brazed or welded partially closed in case the total amount of advance needs to be reduced. I've never gotton that far so I can't say that I've tried any of those methods to shorten the travel.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-12-2003, 06:13 AM
maybe he can find a local speed shop to re-curve it..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-12-2003, 06:43 AM
Banned
thanks everyone
here in Omaha Nebraska theres not much in the way of speed shops but there is one here that may be able to do it.
also
should i have it set as close to the S curve as i can or would something else be better for the setup i have.
S, everything... 1966 911 cams (L)
its a bizo because these dizzys were built for the specific motor S, E, T. so what happens when you have something that the factory never intended on.
Thanks again
Kyle
71 911
Old 03-12-2003, 07:32 AM
jluetjen's Avatar
Given that you're running Solex cams which are the same as the early E cams, I'd recommend that you use the E distributor settings. The following data applies to both the E and the S distributors starting in '69.
You can compare the E to the S distributer curves below. Note that they are graphed against distributor speed which is 1/2 of engine speed.
John
'69 911E
Old 03-12-2003, 09:28 AM
Summit Racing has advance springs. I am using a set in my 930. I nailed it on the second try
Dean
Old 03-12-2003, 12:32 PM
