Certified Pre-Owned
Howdy-
Here's some pics of my recent project that I am actually still finishing up. I picked up my first 911 last year, and it was definetly a project car. Somewhere along the line the hood seal was compromised, which allowed water and other muck into the front compartment, which sat for some time. The car runs well, but certainly has some need for tlc. After a lot of cleanup, stripping and recoating the fuel tank, retaping wiring harnesses, changing hoses, and blending/fogging in the paint as best I could to match...here are the results. The before and after pics have different shades of red as the before pics were taken with a different camera and no flash. Same car. Now on to the engine compartment... -BG
'84 Carrera Coupe |
Nicely done.
Chris '87 Carrera '60 MGA '04 Cayenne |
wow that looks infinitly better. Good job!
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Beautiful job - wanna do mine next?
Randy '87 911 Targa '17 Macan GTS |
Wow looks great- dont even bother covering it with carpet!!
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Certified Pre-Owned
Thanks! No plans to cover it with carpet again. The next item up there is to finish the ventilation stuff, and machine an aluminum bracket setup for that Optima battery...
'84 Carrera Coupe |
WOW
details how you cleaned up the gas tank?? MJ |
Certified Pre-Owned
The tank was stripped on the exterior almost all the way down to the steel with a puddy knife and a heat gun. Extremely tedious and stinky (this took the longest of all of it). I did the top half and a few areas on the bottom. The original coating is a latex based undercoating type stuff, its almost like stripping off latex caulk. I resprayed it with Wurth SKS Stoneguard and their undercoating gun. Pretty easy to apply and low odor.
The dirt on the outside of the original tank was actually some sort of mold that attacked the latex. It would not scrub off and I wasn't keen on painting over it. I also found the seam where the tank halves were welded together to have surface rust forming as I stripped away, so I stripped down further and used a stop rust product before recoating.
'84 Carrera Coupe |
way over the top for my lazy arse, but beautiful job
you removed the tank? thats dedication.
Rich ![]() '86 coupe "there you are" |
Nice work!
Hmm, thanks for the info! As my motor is now assembled this will be my next project. Mine is rusted too and i was just going to scrub and paint, maybe using some Naval Jelly on the seam, but the undercoating is a good idea.
Thanks, Pat
74 911 - First Car Currently Restoring |
Wow! Owning a car that has received the same "outdoor" treatment as yours I now have a lofty goal!
Great job, Jeff |
Incredible transformation! Almost makes me want to jump and there and start working on mine.... well maybe not? It really looks super, and you can tell you've put a lot of hard work into it.
Pls take more pictures of this kind of stuff. I'd really like to see what you do with an engine....
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Thats very nice work.
76 911S Targa |
Wow. You could eat off that thing
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Crusty Conservative
BG-
Looks Great! Now get those headlamp buckets cleaned and waxed inside before they rust on you...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
I have to ask...
Did you say that you stripped the gas tank with a heat gun and a putty knife ?
Was the tank flushed completely before that process ? I just had to ask. Thanks
" It's easy to be a holy man at the top of a mountain". 2001 Porsche Boxster base 2010 Audi A4 2.0 2005 Jeep Grand Cherokee |
Very nice work. The contrast of the components against the red paint is striking.
Warren & Ron, may you rest in Peace. |
Certified Pre-Owned
Thanks for the compliments all...
Was the tank flushed completely before that process ? Nope. The tank was never really "opened", and I covered the open hose connections with tape while redoing it. The inside of the tank from what I could see was fine. I replaced the filter screen (big brass hex part on the tank bottom) and the sending unit gasket while I was there...if I recall I rinsed the inside when I was all done. Anyway, its since had a half a tank run throught it.
'84 Carrera Coupe |
PeterK,
I see you've got an 80SC in your signature. Is that the one from Dallas? Are you still interested in the '84 at Wayzata? Oh, and BG, nice work. Hurry up and get the rear end back together. Spring will be here this weekend.
Nate Gone: '86 Carrera coupe Current: a $75 BMW 320i |
