space between bilstein inside boge strut
Hi guys ,
I was working on my boge strut and put a bilstein shock absorber inside...
and I was wondering if this little space is normal? Did I miss something??
Thanks a lot!
Have a nice day
Old 01-14-2019, 10:40 AM
cdrik915's Avatar
If i'm correct , Bilstein must be mounted in Bilstein strut.
LIGHTER = FASTER !!!
Old 01-14-2019, 10:49 AM
Nop monsieur, bilstein existe for boge strut
Old 01-14-2019, 10:51 AM
Registered Minimalist
75 911s's Avatar
The gap is normal. I did this to my 75 last year and I ran into the same question.
The gland nut literally dead stops a few mm from the top. I did run into an issue where one side came loose. I believe it may have been the safety washer wasn't bent over all the way on the top nut on the insert (in the frunk). Causing it to rotate a bit and get loose.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 01-14-2019, 11:01 AM
So it seem's to be norma! Thanks a lot
Old 01-14-2019, 11:03 AM
75 911s's Avatar
Here are some photos if you want.
- starts about half way down the page.
Old 01-14-2019, 11:07 AM
Exactly the same thing! Perfect ! Thank you very much
Old 01-14-2019, 11:14 AM
The 9 Store
Yes, normal and correct. - I called Bilstein about the first set I did and they confirmed.
All used parts sold as is.
Old 01-14-2019, 01:11 PM
great thank you
Old 01-14-2019, 09:44 PM
It helps too if you use the gland nut tool Bilstein makes for this. If you call them or send email you can buy one (they used to be free). $12 I think. This will allow you to put some good torque on the nut without scratching it up (like if you use a pipe wrench, for example).
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 01-16-2019, 03:43 AM
Thanks for this information.
Unfortunately, I already tightened the nut with a vise-grips. As you said, it makes some scratch on the nut...
But it doesn"t seems to be a big deal.
Old 01-16-2019, 04:48 AM
JMT JMT is offline
This is a electrical coupler I got at Home Depot that I ground down with an angle grinder. I can get a big pipe wrench on it now. I just hope the little lugs don't break off.
Old 01-16-2019, 05:00 PM
Fantastic !!!!!!! Unfortunnately, I don't have your skill nor your tool.
By the way, I 'am rebuilding the front wheel axel unit... as you can see, it was not useless !!
Old 01-17-2019, 09:27 AM
JMT JMT is offline
Thumbs up
If your rebuilding your front suspension you have the skills my friend.
Old 01-17-2019, 10:22 AM
The 9 Store
I use my spanner wrench to tighten. Available at most bike shops for around $15
Old 01-17-2019, 11:29 AM
