Speed Metal Army General
3.6 conversion, where do you route the DME harness from under the seat to the engine?
Just like the title says,, where have you guys routed the DME harness from under the seat to the engine bay on conversions? The car is a mid year
Thanks!
Old 08-03-2019, 10:21 PM
Speed,
lots of 3.6 conversion stuff using "search"...
Here's what I did;
Old 08-06-2019, 04:36 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
basically, the same way the factory did it. Just like the picture above!
Marc
Old 08-06-2019, 03:44 PM
3rd_gear_Ted's Avatar
For my 3.6 conversion track car, I mounted my DME unit vertically with vibration isolation spacers on the rear firewall behind drivers seat. Added another ground strap too. Harness passes thru 1 1/2" hole with big grommet on lower right vertical foot well wall. (harness plugs needed a hole this big to pass thru)
Relays mounted to rear center hump between seat wells.
Also, just didn't want the brain of the car "laying down" on the job
1980 911 - Metzger 3.6L
2016 Cayman S
Old 08-07-2019, 09:38 AM
3rd gear is right......you want to mount the unit on isolators with additional grounding.
Old 08-07-2019, 10:31 AM
This is some great info! Perfect
Thanks guys.
Old 08-07-2019, 06:45 PM
