Clock Not Working: 87 911
I just bought an 87 911 and the clock is not working. Is this a common problem? Is it a DIY repair or is there a recommended specialist out there?
Thanks. |
The interior lights and clock are on the same fuse,
, so if they aren't working either... jt -84 targa |
muck-raker
It's a common problem. I don't know of any specialists, but I believe there are some DIY threads here if you do a search. Many people just "delete" the clock and replace it with some other type of gauge or blank cover.
Before you move forward, check all your fuses and connections to make sure they are clean and tight. You will find that bad/dirty connections are the most common culprit on these cars. Also, the dash gauge cluster (including the clock) will gently pull towards you from the dash...a very simple removal if you choose to inspect it further.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
North Hollywood Speedometer
Palo Alto Speedometer ...are two specialists that are mentioned positively here quite a bit. Google will find them for you.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Member 911 Anonymous
Yeap common issue, either broken solder or internals. Check the tech article on DIY.
+1 check fuses 1st
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
North Hollywood Speedometer treated me extremely well. Dropped my speedo off and went to lunch. Came back and it was fixed and calibrated. Calibration was gratis and the service empecable. Wish I remembered the man's name.
S.
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
The clock is a piece of junk... When I bought my car the clock didn't work, then I bought a used clock, it worked for about 24 hours then took a dump. I removed the bezel (not pretty) and looked at the clock works, for a moment I thought the works had come out of a "Cracker Jack" box.
Bottom line, give it to a professional to repair. Palo Alto repaired mine and it's been spot on every since.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Zink Racer
The clocks both work incredibly well in my 82 and 83 which has always surprised the he(( out of me given how old the cars are and they've both racked up a fair bit of mileage.
Jerry 983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4 |
I too think the clocks are great-incredibly accurate, it stays in sync with my watch, which is renowned for its accuracy. As long as it is over 50 degrees. Below, it stops. Not bad for a 25 year old piece-nothing a good R&R wouldn't fix.
Not the fuses (interior lights work). Ill check out the DIY.
I recently had this problem on my 86 911. the clock comes out very easy and there are just three wires, a ground (brown) hot (black) and the wire for the bulb..no soldering. If you take it out, make sure the black wire never touches any metal or you can cause a short.
You can find used clocks on e-bay or send it to North Hollywood for repair, they will charge you $100 plus $15 for shipping. I bought a clock from a friend of mine in my PCA club, for $50 sold me a clock from a C2, which supposedly are much more reliable. works great, needed just a minor modification/connector to get it hooked up, very easy. If you are interested, carsinc has a C2 clock if you need one, probably he'll sell you one for $60 or so. http://www.carsincnj.com/... ask for Dan, tell him Rob sent you. |
Thanks for the tip. Can you post a photo of your C2 clock? Last edited by Woodyhfd; 07-25-2009 at 04:11 PM.. Reason: punctuation |
This one has a built in light so you'll need to snip the bulb wire and connect it to the back of this clock. The light is much brighter than the old clock, wish my other gauges were as bright. One more thing, this clock was slightly smaller than the stock one I had, wrapped electrical tape three times around and it snugged it up. This is a 15 minute job.
Thanks.
A lot of people poo poo clocks. I like my clock but I fried it trying to connect my battery. I was trying to get the negative cable on and kept hitting the terminal until I got it seated. The clock apparently did not like the voltage surges.
I think I can fix it, I fixed the one in my '71, but I forgot what exactly I did. A small wire somewhere inside? |
I took mine all apart , which was sort of an ordeal in itself, but did not see anything in there that I could fix myself. But now I know how it comes apart.
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
Dead thread revival, but seems like a good place to ask HOW DO YOU REMOVE THE CLOCK ?
From what i "think" i've learned, it just slides out from the dash. If this is true, whats the trick ? I've tried gently, and it hasn't budged.
1987 911 Carrera Coupe 1987 Buick Grand National 1971 Plymouth Roadrunner |
Yes slides out from the dash; either the rubber seal/grommet stays in the dash hole, or it comes out with the clock body. Try twisting and rocking the bezel (turn and pull outward) with fingers to get it started. Might try another gauge (speedo), and if that comes out you can reach in the hole and push the clock from the back. Some people have access (older cars?) to use a broomstick or such to push the clock backside from the front trunk area.
'76 2.7-->3.2 |
or use a spoon as a tool
