Woodyhfd's Avatar
Clock Not Working: 87 911
I just bought an 87 911 and the clock is not working. Is this a common problem? Is it a DIY repair or is there a recommended specialist out there?
Thanks.
Old 07-24-2009, 06:09 PM
JTL JTL is offline
JTL's Avatar
Arrow Did you check the fuses?
The interior lights and clock are on the same fuse,, so if they aren't working either...
jt
-84 targa
Old 07-24-2009, 06:17 PM
muck-raker
kidrock's Avatar
It's a common problem. I don't know of any specialists, but I believe there are some DIY threads here if you do a search. Many people just "delete" the clock and replace it with some other type of gauge or blank cover.
Before you move forward, check all your fuses and connections to make sure they are clean and tight. You will find that bad/dirty connections are the most common culprit on these cars. Also, the dash gauge cluster (including the clock) will gently pull towards you from the dash...a very simple removal if you choose to inspect it further.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-24-2009, 06:18 PM
Woodyhfd's Avatar
jt
-84 targa
Hmmm....I haven't driven the car at night yet, but I don't recall any interior lights coming on either.
I had figured that they were switched off.
Old 07-24-2009, 06:56 PM
efhughes3's Avatar
North Hollywood Speedometer
Palo Alto Speedometer
...are two specialists that are mentioned positively here quite a bit. Google will find them for you.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-24-2009, 07:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap common issue, either broken solder or internals. Check the tech article on DIY.
+1 check fuses 1st
'85 Carrera Targa
PCA/POC
4flyboy's Avatar
North Hollywood Speedometer treated me extremely well. Dropped my speedo off and went to lunch. Came back and it was fixed and calibrated. Calibration was gratis and the service empecable. Wish I remembered the man's name.
S.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 07-24-2009, 10:21 PM
Mitch Leland's Avatar
The clock is a piece of junk... When I bought my car the clock didn't work, then I bought a used clock, it worked for about 24 hours then took a dump. I removed the bezel (not pretty) and looked at the clock works, for a moment I thought the works had come out of a "Cracker Jack" box.
Bottom line, give it to a professional to repair. Palo Alto repaired mine and it's been spot on every since.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 07-25-2009, 06:31 AM
Zink Racer
The clocks both work incredibly well in my 82 and 83 which has always surprised the he(( out of me given how old the cars are and they've both racked up a fair bit of mileage.
Jerry
983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4
Old 07-25-2009, 06:49 AM
efhughes3's Avatar
I too think the clocks are great-incredibly accurate, it stays in sync with my watch, which is renowned for its accuracy. As long as it is over 50 degrees. Below, it stops. Not bad for a 25 year old piece-nothing a good R&R wouldn't fix.
Ed Hughes
2015 981 Cayman GTS
Old 07-25-2009, 03:21 PM
Woodyhfd's Avatar
Not the fuses (interior lights work). Ill check out the DIY.
Old 07-25-2009, 03:32 PM
redranger's Avatar
I recently had this problem on my 86 911. the clock comes out very easy and there are just three wires, a ground (brown) hot (black) and the wire for the bulb..no soldering. If you take it out, make sure the black wire never touches any metal or you can cause a short.
You can find used clocks on e-bay or send it to North Hollywood for repair, they will charge you $100 plus $15 for shipping.
I bought a clock from a friend of mine in my PCA club, for $50 sold me a clock from a C2, which supposedly are much more reliable. works great, needed just a minor modification/connector to get it hooked up, very easy.
If you are interested, carsinc has a C2 clock if you need one, probably he'll sell you one for $60 or so.
http://www.carsincnj.com/... ask for Dan, tell him Rob sent you.
Old 07-25-2009, 03:45 PM
Woodyhfd's Avatar
Thanks for the tip. Can you post a photo of your C2 clock?
Old 07-25-2009, 04:10 PM
redranger's Avatar
This one has a built in light so you'll need to snip the bulb wire and connect it to the back of this clock. The light is much brighter than the old clock, wish my other gauges were as bright. One more thing, this clock was slightly smaller than the stock one I had, wrapped electrical tape three times around and it snugged it up. This is a 15 minute job.
Old 07-25-2009, 04:49 PM
Woodyhfd's Avatar
Thanks.
Old 07-25-2009, 04:57 PM
Zeke's Avatar
A lot of people poo poo clocks. I like my clock but I fried it trying to connect my battery. I was trying to get the negative cable on and kept hitting the terminal until I got it seated. The clock apparently did not like the voltage surges.
I think I can fix it, I fixed the one in my '71, but I forgot what exactly I did. A small wire somewhere inside?
Old 07-25-2009, 05:10 PM
scotricker's Avatar
I took mine all apart , which was sort of an ordeal in itself, but did not see anything in there that I could fix myself. But now I know how it comes apart.
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 07-25-2009, 06:51 PM
Tori's Avatar
Dead thread revival, but seems like a good place to ask HOW DO YOU REMOVE THE CLOCK ?
From what i "think" i've learned, it just slides out from the dash. If this is true, whats the trick ? I've tried gently, and it hasn't budged.
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 08-16-2016, 08:38 PM
Yes slides out from the dash; either the rubber seal/grommet stays in the dash hole, or it comes out with the clock body. Try twisting and rocking the bezel (turn and pull outward) with fingers to get it started. Might try another gauge (speedo), and if that comes out you can reach in the hole and push the clock from the back. Some people have access (older cars?) to use a broomstick or such to push the clock backside from the front trunk area.
'76 2.7-->3.2
Old 08-16-2016, 09:01 PM
or use a spoon as a tool
Old 08-16-2016, 09:38 PM
