Speed Metal Army General
CIS throttle switch questions
So the switch on the side of the TB with two terminals..The little guy that is integrated with the throttle linkage.. What does this sucker do? How to adjust it? The CIS primer mentions it, but doesn't seem to offer any insight.
Without the year, maybe it's the cold start valve micro-switch on 73/74??.
Sorry John, this one specifically. |
El Duderino
In the various Bosch systems, the idea is that once the throttle is opened to a certain point, the system needs to provide extra fuel to enrichen the AFR. JR posted a doc once that showed the states for different year models of the Bosch K-Jet from ‘80-‘83. I think the docs refer to it as angle of throttle opening measures in degrees. It’s basically a throttle switch though. The switch is either triggered or not. I have never seen anything describe how to adjust it. It’s a positional switch so unless it was damaged or bent I wouldn’t think there is a lot to adjust.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
For the early CIS cars (73/74), it performed the function of the thermotime switch in later models. When the throttle was depressed, the switch closed. This completed a power circuit from the positive lead that energized the starter (when you cranked the car) to the 7th injector in the CIS air box to richen the mixture. There is a black handle between the seats that you pull up to start the car. It would move the throttle rod a bit to activate this switch and raise the idle.
What is the year of your car? What engine does it have? is the thermotime switch hooked up?
El Duderino
In the K-Jet w/ Lambda systems the brain cares about certain states. Engine is cold or not (various temp senders). Engine is at idle. Engine is a cruise. Input from O2 sensor is present. Engine is at WOT or not. It is a very primitive ECU by modern standards. Going from memory, WOT is beyond X° angle of opening and where X is defined as a value I can’t remember off the top of my head. 15° is what jumps to mind but can’t say for sure. Anyway, once that switch is tripped it changes the duty cycle of the frequency valve to enrichen the mixture.
Is your car hard to start? Do you need to work the throttle to get it to start and run when cold?
Its very easy to start, dead cold but I do need to press the throttle a bit to keep er running for about say 30 seconds. Almost like a hand throttle scenario. |
Where do the wires on the cold start valve go?
the wiring looks aftermarket. don't know about the switch.
if you engine is a 77 it had no throttle switches. now if someone put on a CIS form a different year that is a different issue. if it does not have a frequency valve, then unless it is from a 73-74 (I don't know about switches on those either) then it should not have one. that hose and crimp on the CSV could be dangerous. I don't see a decal valve on there.
El Duderino
Agreed. That looks sketchy. CIS operates at much higher fuel pressure than carbs. That thing comes loose and you'll be spraying fuel everywhere.
I was wrongly assuming you were talking about later CIS so my answers aren't going to help you. Looks like you've got a cobbled together system. Maybe what you need to do next is step back and inventory what you've got on your hands and what problems you're trying to solve.
Yellow wires are between the starter and thermo-time switch on the left timing cover. The switch, when closed, (throttle open a bit to close the switch) completes the circuit. The CS valve wires both go to the thermo-time switch. When the TS heats up from the starter voltage, it relays starter voltage back to the CS valve, so 12v on both terminals on the CS valve keeps it from working on warm/hot starts when it isn't needed.
All of my CIS is 73-74... Checking part numbers confirms this. Also the lack of a thermotime switch.(which I mistakenly thought I had) What threw me off a bit was the year of my engine. |
