For my completely stock, street driven, 73S MFI system, has not been adjusted or touched for 15 years, other than routine filter replacement. The car starts well, and runs well, and I would not want to change a thing. Others may disagree.
Rob |
Lash
Reference
Besides Pelican Parts when seeking advice check out Early 911 S Registry. Great source of information on the early 911 models.
Lash |
I have been running with a manual push button for cold start solenoid manually operated and the warm up stack removed for over 10 years and over 100,000 miles and monitor AFR with a data gathering system that records RPM, MAP, and AFR. IT IS NOT INFERIOR to the warm up regulator setup.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 Last edited by dicklague; 02-09-2019 at 09:09 PM.. |
How do you know it is running as well as it could be? Maybe the mixture is wrong and maybe you have flat spots that you have gotten used to.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Jeff and Dick,
How can your cars run optimally at all temperatures with ability change mixture according to temperature eliminated (by eliminating the thermostat to the MFI rack)? Its like saying putting a brick on the gas pedal works as well as cruise control. The screw jerry rig will set mixture at a fixed level. It will not allow the car to run richer when cold and leaner when hot automatically which is ideal for a street car and why the thermostat is there. So you either have to set your screw in the middle so it runs when cold and hot (neither optimally). Or set it lean or rich. These cars will run just fine rich but are leaving HP on the table. leaner is faster (but dont run well when lean and cold). Another example, Do you set your timing with just a screw and eliminate the centrifugal (automatic) advance? Chris |
MFI eye candy
![]() Clean enough ![]() My 73 E when just installed but not completely hooked up. |
As I stated earlier in this thread, when I first installed the screw, I would religiously open the deck lid and back it out to its full rich position to start the car when cold. I would drive a block or two or three, pull in somewhere, get out and screw it all the way in to its full lean position. This was admittedly less than convenient. After awhile, I just got lazy about it and left it screwed all the way in to the leanest position. All the time. That was over 15 years ago and I have never touched it since. In that light, calling it an "adjustment screw" is kind of a misnomer, I guess. All it serves to do now is to keep the lever on which the plunger in the thermostat acted pushed all the way forward to its full lean position, all the time. This has resulted in no discernible affect on drivability whatsoever. None. One might think it would run so darn lean when cold that it would hesitate, stutter, pop and bang out the exhaust, and all that kind of stuff. It does none of that. We drive these cars with respect and restraint while they are warming up anyways. By the time the oil temp is up to where we can start having some fun, the thermostat would have pushed its plunger all the way out anyway. So, yeah - just keep the thing screwed all the way in, all the time. Any affect on cold running is trumped by the operational restrictions we self impose while the motor is warming up. You will quite honestly never even notice it.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
(man/dude)
There is, however, a barometric pressure compensation system as well, which would work much more like you are imagining. How much it helps maintain the afr during temperature swings I do not know, but it might be able to predict the weather.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 02-10-2019 at 05:03 PM.. |
(man/dude)
I believe there was a factory bulletin advising the removal of that hot air blend box thing. Not sure the details of that but you'll see quite a few cars simplified to run without it.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
(man/dude)
#1 - I have a supertech manual enrichment system - my observation on the test bench is that the range of enrichment is quite large with this. In your opinion, would it offer enough enrichment for cold start without the solenoid and spray nozzles? Assume ambient temp would be at least above freezing. #2 - I see you also have eliminated the stop solenoid for fuel cut - I apologize if I missed or have forgotten this from your other threads, but can you comment on the before/after effect of that? Assume it's an enthusiast's car and fuel economy is not a primary concern ![]() Also let me say your contributions to the MFI community (of which I am looking forward to being a card-carrying member of) appreciate your efforts to add to the knowledge base! I hope to do the same.
#1) In my experience, no. We have tried a number of methods for starting both my car and my son's '68 912 (with my old '72 2.4) when cold. We have tried it without hitting our priming buttons, with the screw that replaces the thermostat backed all the way out to "full rich". They do eventually get enough fuel in them to start, but it takes an awfully long time, even in warm summer weather. I wouldn't run a street car without the priming nozzles. Maybe a race car, where you would manually prime down the stacks. #2) I have seen no real affect on drivability or reduction in gas mileage. There is such a minimal amount of fuel being delivered when the car is decelerating and the pump is at its idle delivery, and this happens for such a short period of time, that it just does not add up to much fuel. The real intent of the shutoff solenoid is to keep it from popping and banging through the exhaust on deceleration. I've found that few of the many muffler configurations I have tried will do this anyway. Even if they did, many of us now think it's pretty cool to fart a little flame out the pipes... So, yeah, another one of those, to me anyway, "needless complications" on MFI that can be removed on our now "enthusiasts' cars".
Rescuer of old cars
Rather than get a new hose, it sounds I could put the plate and screw in place of the thermostat, especially since I live in a rather mild climate. I'll never need that extra enrichment. Much cleaner look back there without the hose and air blender. Plus, I then have no need for the special MFI left exchanger, if I have no hose to the thermostat and no warm air blender. Am I thinking correctly?
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Yes. The car will run much better and be a bit less troublesome with these well vetted modifications. As far as I'm concerned, the only reason to fuss with restoring these original systems to an operational state would be if you are looking for a faithful restoration, like for concours events or for resale value. If you just want a driver, you are better off simplifying by eliminating these features.
Rescuer of old cars
(man/dude)
It's a 914 ...
I think I mentioned it earlier in the thread, but I have a 914/6 racecar with a 2.7L MFI motor. All the solenoids removed and the warmup circuit deleted from the MFI pump. I start my engine easily with no priming. I just put the accelerator to the floor and it starts every time, though granted I don't run it in cold weather. When I first built the car, I made a priming circuit using the cold start solenoid on the filter stand and actuated by a button on the dash. It worked well, but deleted that setup once I realized that flooring the throttle pedal while cranking worked just as well. One less thing to break or leak gasoline and start a fire.
Scott |
I just made mine from the spacer, or "shim" in the diagram below, that sits between the thermostat and the pump body. I just tack welded a nut to the inside of it.
I guess we all just have to play with it and learn our respective cars. The salient point is that all of that factory cold start stuff can be removed, and these things start and run just fine. It sure saves a lot of headaches trying to keep it all more or less "working".
