LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Throw it on the ground!
"TOOK OUT" My Desert Duty Front Condenser this AM on a drive to the hardware store!
Well, there won't be any charging today! Went through a road construction/ rough rail road track this AM on the way to the hardware store to search for a couple of fittings for today's A/C charging project. Very severe pavement transition. I was only going about 10-15 mph at impact....problem was when I saw how severe the transition was, I braked going into it, lowering the front end further.......A total cluster Cage came loose and was dragging till I could pull over and check the carnage. Check out the pics.....impact actually creased the tub between the condenser and gas tank!
This was my first time over the tracks since I lowered the bar. Would just lightly tap the skid plates before.
For those who have been following my project, recall that I lowered the crash bar but had not yet mounted the center mount of the bar.
Griff, I'll be placing an order for your front condenser!!!!
For the record, the chunk was already missing from the front chin spoiler.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 03-29-2008, 08:53 AM
Gasoline User
1974carrera's Avatar
Major bummer, Mark! I've followed your installation and know you've gone to a lot of effort, and expense, only to arrive at this point. It looks like the crash bar is still in place...was the rock guard/condenser still lower than the crash bar even though you had lowered the bar?
Hang in there...you'll recover from this.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 03-29-2008, 09:14 AM
Elombard's Avatar
That sucks, I feel your pain, what is that $200 + down the drain
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 03-29-2008, 09:30 AM
That's frustrating! The engineer in me wonders is it still leak tight; how much damage can these units take?
Also looks like the lateral chassis tube was punched up some on the driver's side. There's likely a reason why Porsche went to front fender mounted condensers in the later cars - combining the function of a condenser and a skid plate results in a heavy component that is not optimized for either function. I also think the belly mounted condensers are a bad idea. Griffith's rear fender mounted condensers make more sense, especially in a lowered car.
Good luck with the repairs and revisions.
Old 03-29-2008, 09:32 AM
Send a message via AIM to fintstone
Tough break!
I was afraid of that when I did my '74 because it is so low in the front...plus, since mine was a non-A/C car...I didn't want to make the cut-out...so, thanks to Jim Sims advice, I used the dual-Keuhl ones that go in the front and back of my left wheel well. Good luck on the fix.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-29-2008, 09:35 AM
(the shotguns)
berettafan's Avatar
Wow that's a bummer!
Old 03-29-2008, 09:52 AM
4flyboy's Avatar
Son of a b@#tch.........you are showing remarkable composure! I would have been too pissed to post. Way to get into the solution. Subscibed.
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 03-29-2008, 10:19 AM
Front condenser stone guard 911.573.058.01 $146.75 new or $40.00 used.
Don't know why I thought they'd be cheap. Guess I'll be bending it back into shape!
Mark
1987 911 Coupe
Old 03-29-2008, 10:54 AM
The AC's on 911's are just begging to be removed. Such a stupid place for a condenser in the first place. Here's your golded opportunity! And it won't cost you anything.
Old 03-29-2008, 11:12 AM
khamul02's Avatar
I'm running the same condenser. It is the lowest point on my car and it is very scary. I guess if I this happen to me I would just replace it with a lower profile condenser.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 03-29-2008, 12:31 PM
kuehl's Avatar
Salt on the wounds. The Oath of Hippocrates, doc?
Mark. Take the rest of the day off. We'll help get you back on the right
road. Your Kuehl unit and o-rings are in transit.
If I find a stone guard in the "barn" we'll throw it in the box.
Griff
Old 03-29-2008, 12:49 PM
Griff
Mark
1987 911 Coupe
Old 03-29-2008, 01:10 PM
Mark, once you remove the damaged condenser keep it. Mount it on the wall in your garage as a "trophy" of your project. Right now you are feeling the pain, in a few months or years you will have a neat but very warped trophy for the garage. If nothing else no one else will have a brand new never used, bent and destroyed front condenser like yours.
Old 03-29-2008, 01:50 PM
OldTee's Avatar
Don't feel bad. I know somebody who forgot to put the big washers on the top of the motor mounts and after driving a few miles the engine fell out. He was lucky it happend at the bottom of his driveway and only took out some fuel lines and the main engine electrical connection. It was a older SC..
Old Tee
all 911s sold
Old 03-29-2008, 02:54 PM
What he said. Hang in there!!!!!! How's the financial adviser, (aka wife), taking it?
O2 In Sully We Believe
Old 03-29-2008, 02:56 PM
Toxic
derkpitt's Avatar
Mark,
My deepest sympathy.
If it will make you feel any better, I got the other N2 bottle back from filling, if you need it later.
Bruce
88 Carrera Coupe, 12 Dodge Ram Hemi,
69 Barracuda Fastback, 68 Barracuda Convertible 5spd
The only substitute for cubic inches is cubic dollar$.
Old 03-29-2008, 07:50 PM
Oh don't you know it! That was the worst part. Explaining that not only was the project not completed after 3 weeks but it would cost more $$$. We got her an iPhone today....this may work!
Mark
1987 911 Coupe
Old 03-29-2008, 08:05 PM
Originally Posted by derkpitt View Post
Mark,
Bruce, the fitting on the Nitrogen set up is for R12....can't connect with my 134a hoses. Went shopping for a 134a set up today with not luck........hardware stores are a no - go. No luck at NAPA either. Will check the A/C sites tomorrow.
As we discussed, better to wait and get it right than to rush to complete the job!
In hindsight, today was a crappy day for charging anyway.......62 degrees and rain!
This A/C thing is like war. Never give up, never, never, never!
Mark
1987 911 Coupe
Old 03-29-2008, 08:18 PM
This it truly the best idea of the day.........I'm already thinking of some mounting ideas!
Mark
1987 911 Coupe
Old 03-29-2008, 08:22 PM
khamul02's Avatar
WAR !!!!!!!!!!!!!!!!
we shall fight on the beaches,
we shall fight on the landing grounds,
we shall fight in the fields and in the streets,
we shall fight in the hills;
we shall never surrender
Tom Hutchinson
Old 03-29-2008, 08:36 PM
