Coloradocurt's Avatar
Steam Cleaning Underside
Anyone know of a place/shop/service/detailer in the Denver-Colorado Springs area that (for a fee) could put a 911 up onto a lift and steam clean the underside?
Old 02-09-2019, 02:47 AM
Recreational User
porschenut's Avatar
The Man Cave does engine steam cleaning, so I'm sure they can do your underside. I've never been there personally. The Man Cave | Auto Detailing Denver CO
Old 02-09-2019, 07:09 AM
786 786 is offline
786's Avatar
Anyone know of a place in DFW?
Old 02-09-2019, 07:14 AM
Can’t say about Denver or Dallas but here is my car being steam cleaned in NorCal
1966 912 to 2.7 Frankencar
Old 02-09-2019, 04:49 PM
Hoover,
I am in the east bay. Does that read San Jose steam clean?
Can you share what you paid?
Old 02-09-2019, 05:54 PM
Is steam cleaning safe on 30-40 yo cars? Isn't there a risk of steam penetrating narrow passes in the body and reviving/starting corrosion?
Old 02-09-2019, 07:14 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Dry ice.
Consider dry ice?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-09-2019, 11:39 PM
be careful with dry ice. Can do a lot of damage to softer materials
80SC (ex California)
Old 02-10-2019, 02:45 AM
piscator's Avatar
While not as powerful as a commercial unit, I've gotten helpful results from a wallpaper removal steamer, I purchased at Home Depot. It doesn't produce much pressure, so it doesn't 'blast' off the grime. But steam is steam and it is HOT!
For cleaning in tight spaces, you can cobble up a wand, or just use the hose. I found it especially effective for 'pin point' steam cleaning the engine and transmission. Armed with the usual arsenal of brushes, sticks, Simple Green and the patience of Job -- the steamer did a good job loosening the thick stuff.
Once the heavy dirt is off, the steamer does a great job of removing the dinghy haze from the aluminium. Point the steamer and watch the dirt run off what you thought was a clean surface! Your intakes will positively sparkle! :-)
I also used the steamer to clean the wheel-wells. Less effective here, but still helpful. The heavy grime in the wheel-wells needed brushing and detergent to break it up. I used the steamer as my 'hot rinse'. Much better than using my hot water hose. Also, without the steamer I would probably have used twice as much Simple Green. Here again, the steamer did a great job getting that last surface layer of grime.
Incidentally, at a nearby industrial plumbing and boiler shop, I found stiff, long bristled brushes used for cleaning A/C 'fins'. Oriented vertically (as opposed to a horizontal toothbrush) -- they work great cleaning engine cooling fins.
I also bought another tool for the same purpose, which has contiguous metal fingers, bent 45 degrees; in the shape of a hand. Looks a bit like a hand-rake gardeners use in a flower bed. This is a 'must have' tool for getting the heavy gunk out of the engine fins!
Whenever I use tooth-brush style wire and bristle cleaning brushes, they get all bent and 'mushed up'. I must go through a dozen at a clip! The stuff I picked up at the industrial boiler supply has paid for itself, just in 'mushed up tooth-brush' savings!
Lastly, I bought the wallpaper steamer to steam-bend ash canoe rails. If you're interested in a steam source for wood bending, these units work great.
Sorry to go on like an infomercial, I just wanted to share my recent experience.
Robert
Old 02-10-2019, 05:14 AM
i had the underside of several of my cars steam cleaned on a lift like that. I just have them avoid the body areas, focus on mechanicals mostly. Turns out great. Allows you to also see what undercoating needs a touch up, etc.
For a cleaner, I use simple green aircraft cleaner. Its safe on aluminum and all metals. I use a soft boars hair brush. Really the steam cleaner is for getting caked off crap off the motor if there was oil seepage.
My 89 carrera looked like a new car after getting this done, original cosmoline and all.
Old 02-10-2019, 07:35 AM
Originally Posted by spyerx View Post
........ Really the steam cleaner is for getting caked on crap off the motor if there was oil seepage. .......
That's my primary objective! Wheel wells can be done pretty easily at a DIY car wash if you want to make the effort to jack up each side of the car (individually!) and remove the wheels.
Old 02-10-2019, 08:01 AM
T77911S's Avatar
be careful who puts your car on a lift.
I NEVER let ANYONE put my car on a lift unless I am there
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-11-2019, 05:01 AM
I'm good with tools.
AG81's Avatar
I did mine with simple green on jack stands...... I did not want to clean up the mess after using my lift. Pressure washing is fine....JUST BE MINDFUL OF THE AMOUNT OF PRESSURE !!!! There are pressure washers that will cut stone..... 150 psi is plenty of pressure.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
02 996 4S (owned since new - heavily optioned)
Old 02-11-2019, 06:12 AM
My car looks just like your before pictures. So you did all this with a pressure washer and simple green?
Old 02-11-2019, 07:44 AM
AG81's Avatar
Derek,
I did. A brush, an old toothbrush, simple green, a bucket, warm water and a home owner type power washer at about 120 psi. Oh and jack stands.
Prepare to get dirty......
Old 02-11-2019, 07:48 AM
proporsche's Avatar
i agree with Adias..be very careful when you steam or clean procedure of the rear fenders.There is a factory foam between the body and fender.If you spray up the foam will be soaked with water and you will have soon rusty spots there..I have seen it on several occasions..front is more safer..
Ivan
1985 911 with original 501 587 miles...807 226 km
Old 02-11-2019, 08:02 AM
Lund's Avatar
Ivan
is this up in the channel from the rear fender to the roof.. along the rear window?
Old 02-11-2019, 01:42 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Derek,
+1
I did my front inner fenders with kitchen Fantastik and rags. Just as spiffy as AG81's pics. A lot of credit goes to Porsche for the durability of their coatings. It was just grunt work.
1981 911SC Targa
Old 02-11-2019, 02:58 PM
Derek,
Turned out really nice, but man I hate pressure washing. I grew up in Arizona where no one has a pressure washer. Now in Florida and you have to pressure wash everything. Ah what the heck I’ve gotta try it.
Old 02-11-2019, 03:28 PM
H-viken's Avatar
No need for a pressure washer, if you are concerned about them (I'm personally not a huge fan). Elbow grease and hot matter will do wonders. Couple of dish brushes and some type of soap (simple green sounds good)
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 02-11-2019, 08:33 PM
