Does anyone make a composite rear window for a 911?
I'm looking for a light weight rear glass option, it seems there should be a gorilla glass or lexan type composite option for these cars. Besides lighter weight I am also looking at getting rid of the defroster grid lines in this process. It seems with all the resto-mod options out there this should exist however I cannot find any.
Fiberglass and carbon fiber body panels but I cant find a composite glass....
Thanks!
Old 02-13-2019, 07:04 AM
I'm good with tools.
AG81's Avatar
One Option:
http://www.fivestarbodies.com/store/index.php?p=catalog&parent=87&pg=1
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 02-13-2019, 07:09 AM
AG81's Avatar
Option #2:
https://www.plastics4performance.com/window-kits-windscreens/porsche-911-pro-lexan-rear-screen.html
02 996 4S
Old 02-13-2019, 07:10 AM
Hilbilly Deluxe
emcon5's Avatar
Make one. Find a local plastics supplier and either buy the sheet, or get them to cut it for you.
82 911SC Coupe
GTI Cup #43
Old 02-13-2019, 07:40 AM
WOW! Thanks AG81. Both of those look like great options. Have you had any experience with either?
Old 02-13-2019, 07:59 AM
is there a targa option?
1980 911SC Targa 3.6L
Old 02-13-2019, 08:04 AM
AG81's Avatar
No experience first hand......
02 996 4S
Old 02-13-2019, 08:20 AM
Cory M's Avatar
I've used 5 Star and Shields for 911 and 914 racecar front windshields in the past. Both were good, no issues. For the rear windows I just get a flat sheet from the local plastics store and cut it with a jigsaw because it's much cheaper.
Old 02-13-2019, 08:53 AM
Mahler9th's Avatar
Five Star make great products... a Wisconsin company. I have used 2-3 of their windshields.
I make my own plastic rear windows. I use PETG instead of polycarbonate.
Racing Shields also make plastic rear windows (SHIELDS Premier Windshields - Racing Rear Window Pricing and Models).
I recently bought a 3/16 Racing Shields rear window via the PP forums. I do not need it, so I will advertise it in the forums.
It is a Racing Shields 3/16 inch thick 911 rear window.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 02-13-2019, 09:01 AM
Mahler9th's Avatar
For the sake of clarity:
Polycarbonate is often used. The GE version is called Lexan. Crack-resistant, but prone to scratching. This material is often used for front windshields in racing applications.
Plexiglass should NEVER be used. The generic name for plexiglass is acrylic. While scratch resistant, it is prone to cracking and is therefore NOT suitable for windshield applications. Some racing organizations may not allow it for rear windows either.
PETG is what I use for rear windows. It has optical clarity and scratch resistance like acrylic/plexiglass, but is more crack-resistant like polycarbonate.
Mike
BMWCCA
NASA
Old 02-13-2019, 09:06 AM
Platinum Member
dad911's Avatar
gt-racing has windows and frames.
Old 02-13-2019, 09:22 AM
Thanks everyone. I am going for the factory look as well so I do not want visible rivets or bolts around the boarder of the window. It looks like one of these guys can do that.
Old 02-13-2019, 09:30 AM
Kraftwerk's Avatar
What is the proper thickness of Lexan/PETG to use? Can the rubber-surround seal be re-used?
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 02-13-2019, 10:00 AM
Aircraft Windshield Co. in Anaheim, CA are 3rd generation family run and make terrific products. I have used them many times on my non-Porsche race cars and highly recommend them. They also make the "glass" for many of the factory prototypes you see at auto-shows as well as windscreens for a variety of racing series.
Aircraft Windshield Company - Home
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 02-13-2019, 11:51 AM
Do you always have to use metal straps when using composite style windows in the rear to keep them from blowing out. I’d like to use them but do not want to screw them in or use the metal straps.
78 911 st backdate
87 944
00 996
Old 02-13-2019, 06:24 PM
Nux Nux is offline
Nux's Avatar
Lindsay Racing have them on their site. Don't know if they still make them. I just emailed them about it.
I made my own polycarbonat rear window. Very cheap and very light, but needs to be bolted to the frame:
Old 02-13-2019, 11:47 PM
Mahler9th's Avatar
For racing applications, it is always a good idea to see if there are rules for windshield minimum thicknesses. Of course, even in the absence of specific rules, folks should be prudent. I think most manufacturers use 3/16" thicknesses as a minimum for windshields.
I have been using 3/16 inch thick windshields for my '75 911-based race car for just under 20 years. At this thickness, the windshield can bow inward, so I have a simple brace that is attached on the backside of the mirror to support it. I have quite a few friends with similar set ups, and others use 1/4 thick windshields.
In my case, the windshield is mounted with a later 911-style rubber windshield gasket. It sits pretty flush and works very well. I use two lower alu support straps as an extra measure of security in case of a spin that puts excess pressure to blow the windshield out.
For the rear, I have a custom set-up very similar to what you could buy from companies like Automotion back in the day. An ABS frame and a flush-sitting piece of 1/8 inch thick PETG.
When I bought the car, it had a 1/8 thick piece of polycarbonate as a rear window, again mounted in a rubber seal.
Mike
BMWCCA
NASA
Old 02-14-2019, 08:59 AM
Send a message via AIM to blockhed
https://www.eb-motorsport.co.uk
Old 02-14-2019, 09:17 AM
