M491Cabriolet's Avatar
Engine keeps running with ignition switched off
Hi all. Ok, more problems to resolve on a 911. The car is a 1982. This one is fun and I can’t find any solutions using the search button. I turn off the key and the engine keeps on running. This started when I retired the frunk fuse box. Clearly, I got something wrong... as it is now, I’m shutting it down by stalling the engine, which isn’t the best solution.
Can anyone point me to a potential solution? Thanks!
Old 02-20-2019, 03:24 AM
T77911S's Avatar
check for power to the CD unit with key off and then on.
if power there with key off then look for what wire/fuse has power with key on.
some fuses are suppose to have power all the time.
by retiring the frunk fuse box I assume you mean you replaced it/upgraded it
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-20-2019, 06:06 AM
Thanks! Sorry, I meant to type rewired, note retired! 👀
Old 02-20-2019, 06:15 AM
Oh, and here is another stupid problem... In retiring the windshield wiper motor, I can’t figure out where the ground wire(s) connect. I can’t find the connector anymore. It all works when I touch the ground to the motor body. Any help would be appreciated!
Old 02-20-2019, 07:06 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Once you turn the key off (and the engine is still running) step on the brake and/or raise the handbrake and see if it shuts off then..
Marc
Old 02-20-2019, 07:41 PM
Rescuer of old cars
Arne2's Avatar
Might be a bad diode in the alternator.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-20-2019, 07:43 PM
Senior Member
Superman's Avatar
Your flux capacitor is shot.
Rather than dump the clutch to stop the motor, you can always just pull the red fuel pump relay. This, in the meantime.
Long term, it sounds like you need to spend some time with a wiring diagram.
Mocha 1978 911SC. "Coco"
Old 02-20-2019, 08:56 PM
