Costco will not sell me shoes for my 86 Carrera
Went to get some new shoes for my 86 which currently has 205/55/16 - 255/50/16 stock. I recently bought some 8's/16 for the back and costco will not put the 7's in the front and the 8's in the back, as it's a liability for them...........................ARGGGGG!!!!!!!!!!!! !!!!!!!!!!!!
Senior Member
The 7s will not fit in the front, I believe. Wrong offset.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Yes, I believe Costco won't stray far from stock sizes. Your series Carerra '84-'89 all had 6" fronts as stock I believe. BTW - did you mean your current sizes are 205 & 225?
I tried to get some tires at Costco for my wife's car and was fortunate enough to get a different tire size than originals because the diameters were less than 3% larger than stock for that year. It would be nice if they just had the customer sign a waiver saying they understand the different tires may change the characteristics of the car and waive Costco liability. Seems it would run a bit deeper than that however. |
Can you just bring them them wheels to mount the tires to? 2 wheels at a time?
I never bring my Porsche to get tires- always just bring the wheels. DD, they can have the car too!
Rutager West 1977 911S Targa Chocolate Brown |
The ‘86 had three wheel sizes offered:
Stock were phone dials 15x6 with 195/65-15 and 15x7 with 216/60-15 Fuchs option of 15x7 and 15x8 with the same tire sizes 2nd Fuchs option of 16x6 with 205/55-16 and 16x7 with 225/50-16 On my first ‘86 that I had ordered new I ordered with stock phone dials not wanting to pay an up charge for Fuchs since I had a set of Fuchs 16x7, 16x8 that I was going to take off my ‘83 SC that I was trading in. But the car got built with the damn 16” Fuchs, seems the factory assumed since I’d spec’d the car with spoilers, limited slip and sport seats that I must have forgotten the “performance” 16” wheels. So the dealer took the phone dials off another new 911 in the showroom to put on mine and took the up charge off the price My current ‘86 was delivered New with the 15x7,8 Fuchs per the options tag, were still on the car when I bought it in 2008. The reason I share all this is because perhaps the OP can tell the tire shop that in fact 7&8” wheels were a factory option, just don’t tell them it was 15” instead of 16. Rolling diameter of the 15’s and 16’s is virtually identical. However, on all the SC’s and Carreras I’ve owned over the past 35 years I’ve had to roll the front wheelwell lips to move the 7’s from the back to the front.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Moving the 7's up front will work; I did the same thing with my '86 when I added 8's to the back. You may want to roll the fenders though, especially if your car is lowered.
The 7ET23.3 whether 15 or 16 fit the front fine, lowered cars may need a bit of work at the lips
should be 225/50 x16
Wheel and Tire size.............
I currently have 7x16 Fuchs front wheels with 205-55-16 tires and 8x16 Fuchs rear wheels with 245-45-16 tires. Sizes fit well with no front fender interference and the car is sitting at just a tad lower than the Euro height. With this arrangement, the car handles great. The one size larger rear tires got rid of most of the oversteer tendencies the car was experiencing. When the car needs tires, I pull the wheels and take them in to a shop to have the new rubber mounted and balanced. Maybe Costco is not the place where you need to shop for tires?
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
I factory ordered 7&8s 16 on my 1988 911 paint to sample car back in the day.
As for Costco you can order the tires just have them installed at a local indy shop. I use Costco prices and have Americas tires price match and install. My local America tires shop is great to work with.
PCA, POC & SCCA long time Member |
they mounted tires on 7/9 euromeisters for me. I made no mention of car model or make
1979 SC 1986 Carrera 3.6 L+ |
Registered Minimalist
Last time I had work done there they damaged both wheels
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Last time I used Costco the car came out with the tires marked outside on the inside, never again...and it wasnt the P car, I just take the wheels in for that one
I think that maybe I'm dreaming.. |
I have had no problems at the local Costco with tires for the family cars.
Purchased tires from tire rack last yr. And had a local performance shop mount and balance them. They race and service mostly Lotus and some Porsche. |
Under the radar
The last time I used Costco, I had the same issue.
PLUS the manager was IGNORANT and DISRESPECTFUL. He became incensed when I proved that my wheels were in fact 7" when he had incorrectly measured them at 8". I had a Panorama in my car to show that in fact 911s used 7 and 8" wheels. I can share other stories, but at least in San Diego at more than one location, I am not sure what they were smoking. I have said it before, if you go to costco for tires, you will regret it. JMO
Caveman Hammer Mechanic
Costco, dogfood and toilet paper.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Same here. Zero chance I turn my car over to a tire shop or worse yet Costco. That’s just asking for crushed oil lines and stripped/cross threaded/ruined alloy lug nuts.
_______________________________ 1982 911 SC 240,000mi and counting |
I brought my car to an Indy tire shop...owned by a PCA member, and the installer almost crushed my oil lines when jacking up the car. From now on I remove the wheels and just bring those down for a tire swap....much less stressful. Sent from my iPhone using Tapatalk
‘84 Carrera, heavily modded Please follow me @chopped_up_fitness |
Under the radar
Even just bringing the rims can be scary enough.
