Rolled Front Fender Lip | Hand Tool Method
There are many ways to roll fenders, but I had the luxury of forming my fenders on a bench before paint.
I have a lot of respect for those of you who have done this without cracking the paint.
I was able to get a tight edge...about .175". That gives me almost a 1/2" of extra tire clearance from stock.
A small gap was left so I can protect it from rust and clean it out from time to time.
Here's the video:
https://youtu.be/2p-EJJAGkuI
www.ahhgaragetime.com
Old 02-23-2019, 10:42 AM
Following
Old 02-23-2019, 10:46 AM
Bill Verburg's Avatar
Here's the video:
The problem w/ folding the lip like that is the dirt trap that is created, if not kept clean it will be source for corrosion.
You are much better off trimming the lip back w/ a body hacksaw
Bill Verburg
Old 02-23-2019, 10:56 AM
Thanks Bill,
The lip pictured has been trimmed by half of the distance and rolled. I don't mind cleaning this area out every once in a while and I feel the rolled edge is much friendlier to my tires if contact does occur.
Tom
Old 02-23-2019, 11:22 AM
They grind down pretty easily too, rust inhibitive primer and touch up paint.
Old 02-23-2019, 11:35 AM
Rolling the fender lip is a common method of eliminating tire rub. However, not all owners are aware the trough created can trap road debris and moisture. Suggest adequate surface prepping, then fill the space with silicone caulk or equivalent weather-protective material.
Sherwood
Old 02-23-2019, 12:45 PM
