jakg104's Avatar
Tire choices for a 77 911 narrow body. CN36, avons?
Hi folks,
Working on getting tires for my 77 911 narrow body with a 3.2 motronic engine. Car sits on 6x15 and 7x15 fuchs. Car came with a square setup for tires- 205 60 15 Falkens.
Ideally I'd like to get period correct tires that are in the 25" height so it fills in the wheel well, but cannot find good brands with sizes.
I'm thinking ideally 195 60 Front, 205 55 rear, or 185 70 Front, 215 60 rear. I do see Pirelli P6000, but nothing else..
Thoughts on other tire size combinations and brands that could potentially work?
@bill verburg would love to hear from you as well!
Happy Thanksgiving!
Jake
71 911S 3.6
Rosewood 82SC
92 964 ROW- Sold
97 993 Coupe- Sold
Old 11-22-2023, 10:19 AM
Bill Verburg's Avatar
Originally Posted by jakg104 View Post
Hi folks,
Happy Thanksgiving!
Jake
215/60 on a 7 will be problematic unless the wheel has an o/s in the 25-29 rarnge
7 ET23.3 will rub on full compression a couple of inches above the lip, so ET that moves the wheel in a few mm is what is needed.
The other tires are short enough to not be a problem
lastly watch the f/r tire height, you really want to keep them relatively close to being the same
Bill Verburg
Old 11-22-2023, 10:32 AM
Mr. Merk's Avatar
The RS spec sizes of CN36 seem like a no brainer to me, assuming the offset is correct. May be able to dial in the negative camber to keep from rubbing under full compression.
We have these on a 75 Carrera with 7s & 8s. So good.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 11-22-2023, 01:10 PM
There's a big difference as to what works on a n/b and what works on an SC/Carrera body
also '73 - '75 RS spec was 6 & & x15 185/70 and 215/60, widest wheel specs for these sizes is 6 & 7.5", Though the factory did offer them on 7 & 8 in '75 & 76
Bill Verburg
Old 11-22-2023, 02:01 PM
jakg104's Avatar
Ah! good point on the 215 not working in the rear... I'm tempted to go back with what the car has, the 206 60, but choices for a decent, period correct tire are a challenge..
71 911S 3.6
Rosewood 82SC
92 964 ROW- Sold
97 993 Coupe- Sold
Old 11-22-2023, 02:21 PM
jakg104's Avatar
Mr. Merk, the issue will be that the RS/Carrera has wider rear flares, the narrow body is, well, narrow. Would have been easier if it was a Carrera flare car..
71 911S 3.6
Rosewood 82SC
92 964 ROW- Sold
97 993 Coupe- Sold
Old 11-22-2023, 02:22 PM
Full Send Society
215s will fit on 7” Fuchs in the rear. You’ll need between 1.5-2 degrees of negative camber and might need to roll your fenders, maybe not. All really depends on the tire profile but I had 215x15 Dunlop direzza on my narrow 1977 until I changed out to 6 x 15 wheels and taller tires for a more lively feel. Also Chicago potholes.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 11-22-2023, 02:52 PM
What tires are you running now?
Old 11-22-2023, 03:12 PM
Full Send Society
I have 6x15 aluminum steelies form Group 4 and I have riken raptors 195x65
Fat meaty and a lot of fun. The Direzzas were too rough of a ride and made the car boring.
-Julian
Old 11-22-2023, 03:36 PM
I'm currently using Pirelli CN36 215/60/15 at the rear of my 70S, and P6000 216/60/15 before that. CN36 has way better grip, smaller dimensions, looks better, and I think (but not sure) lighter as well. Wheels are Fuchs 7R.
Old 11-22-2023, 03:49 PM
jakg104's Avatar
Looks great! Where are you buying the CN36 from?
71 911S 3.6
Rosewood 82SC
92 964 ROW- Sold
97 993 Coupe- Sold
Old 11-22-2023, 04:39 PM
jakg104's Avatar
Man, i really want to avoid rolling the fenders. I prefer a lower(ed) look, so car will have some camber, but would prefer to not mess with fenders.
Great to hear about the Riken raptors...
71 911S 3.6
Rosewood 82SC
92 964 ROW- Sold
97 993 Coupe- Sold
Old 11-22-2023, 04:41 PM
Jakg104, I bought them at P Zero World in Los Angeles.
Old 11-22-2023, 05:11 PM
mar2mar,
Looks good. What is the thickness of the spacer you're using? And how much negative camber?
Old 11-22-2023, 05:54 PM
Thanks blue72s, spacer is 5mm. Camber -1deg.
Old 11-22-2023, 07:36 PM
jakg104's Avatar
Thanks! I’ll give them a call to see if they can ship to Texas.
Old 11-22-2023, 08:09 PM
mar2mar,
Thanks. Would you mind to take a picture like the one below to see how close your rear wheel & tyre (w/ 5mm spacer) is to the trailing arm?
Old 11-24-2023, 10:23 AM
I have a 75 narrow body and struggled with tire choices as well. I know this doesn't help if you stay with 15" rims, but I went up to 16" Group4 wheels because 16" offered more tire choices. I also didn't want to roll my fenders so I went with 195/55/R16 (~24.4 in tire height) Bridgestone POTENZA RE-71RS. They were a fraction of the price of the Pirelli P4000, but again this isn't helpful if you want to stay period correct.
Old 11-24-2023, 05:40 PM
blue72s, with a 5 mm spacer the gap between toe adjustment bolt and tire is about 2.8mm. I’ll switch to a 7mm spacer, after taking the photo, It looks like there are tell tale signs that it lightly rubs on occasion.
Old 11-25-2023, 11:35 AM
Woah! that is way too close. Good job I asked you to take a picture. I would use a 13mm spacer at the very minimum. Tyre sidewall can flex during cornering.
In fact, the factory Sports purposes manual (1968) recommends 27mm spacer.
Old 11-25-2023, 03:30 PM
