Top mph speed on stock '88 3.2?
Anyone know what the factory says the top mph speed on a stock (US) 1988 3.2 is? If so, is it pretty accurate in the real world for an unmodified engine?
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Fleabit peanut monkey
There was a thread on SC top speed in the last several months.
It was all over the map. My guess before the fun begins is (without research) 143mph. A guess. You want true/accurate? Check the SC thread and see how comfy you feel with the responses. Finally, one or two of the big boys stepped in and chilled the crowd out.
1981 911SC Targa |
1988 Carrera
Factory spec is 149 My did 148 according to the GPS.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
new goal - thanks!
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Hilbilly Deluxe
Car and Driver reported a tested at 149 in 1984.
https://members.rennlist.com/emcon5/84-911_C-N-D.pdf |
Interesting. I bought a copy of the "Porsche 911 Perfection by Design" book (Leffingwell) and didn't really see anything about top speed for the late model 3.2's. Lots of other good information, though.
Had my US spec 1988 3.2 in Germany for three years. Winding it up to the bottom of the redline at 6200 RPM in 5th gear netted 135 mph through the speedometer showed a bit higher. Probably would peak in the low 140s going into the red band.
Two videos: First is following a new 911 at about 135 mph. https://youtu.be/QEU6AxmjNC8 Second is a run from the Austrian border at sunrise on A7 to A8 heading back to Stuttgart https://www.youtube.com/watch?v=Qk9QHLM9KYU
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
Recreational User
Did you look on page 95 of your owner's manual?
Does page 95 state what the speedo will say or GPS?
A bit unfair to ask, but Man, the speedo error in these cars is huge once you change into a new set of shoes.
1981 911SC Targa Last edited by Bob Kontak; 03-01-2019 at 05:33 PM.. |
Yep...When I pushed the 88 hard right up to 6200 RPM, the speedo would read high 150s/low 160s, but GPS in low 140s.
Recreational User
That leaves a little wiggle room.
1981 911SC Targa Last edited by Bob Kontak; 03-01-2019 at 07:23 PM.. |
I saw mine needle just over 160, just glanced quickly, when I was part of a closed freeway run. It took a while to get there. Prob what broke my headstuds too. Accuracy? My gps had died so no reference. That said do the gearing from a lower rpm in 5th. I think it runs out of gear at near 155.
Mine is a lowered 89, fab speed exhaust and headers, SW chip. So not stock.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
According to Tobia Aichelle, who collated the most factory data you could imagine in his book: "Porsche 911 - Forever Young", 245kph (roughly 152mph) was what the factory quoted for all versions of the C3.2 over it's lifetime. No info provided for the lower HP versions.
By comparison, all versions of the SC were quoted at 235kph |
Top speed for any car will depend on the aero characteristics, transmission specs, tire specs, engine specs, and the specifics of how the car is setup.
Factory spec is 245kpm(152mph) for Carrera w/o cat and 240kph(149mph) for Carrera w/ cat, the ride height and tires can be assumed to be stock 225/50x16 but they don't specify the aero configuration. These cars are going to be aero limited as the theoretical top speed at the redline 6500 is ~156+/-2 mph depending on the specifics of the tire and motor
so all this makes my old 1977 911S doing 125m/h pretty good speed;-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Top MPH.
![]() ^^^^^ Fresh out of the factory-On the Autobahn. Don't know what happened to the last 700 RPM's........ Maybe headwinds? A bit fuzzy as I was holding the camera, and my wife had a firm grip on the dash ............ G.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 03-02-2019 at 07:56 AM.. |
I'm good with tools.
Interesting topic..... my 88 coupe is extremely quick off the line and a bit lighter from stock. I am not at all interested in being near that speed inside it. As Bill said above the aero characteristics are going to be limited. It I am going to go that fast I want a full cage.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
another thing that I forgot to mention is that there were 3 different trans. depending on the market the car was built for
g50.00 for most of RoW has a theoretical top of 156mph +/- g50.01 for US Can, J has a theoretical top of 151mph +/- g50.02 for Switz. has a theoretical top of 156mph +/-
