Brap
tmaull's Avatar
Engine Rattle - Help!
My car has started making a god awful rattle. It’s either a harmonic with the engine or in the engine itself.
Characteristics
- Rattle occurs at approx 2800-4500 under moderate load, most audible in third and fourth gears
- Completely goes away when I declutch
- Is inaudible when I shift to fifth at highway speed
Other info
- Engine rebuilt approx 3000 miles ago
- Only recent change was the installation of a wevo shifter and psj
I’ve uploaded a YouTube video, although it doesn’t quite do the rattle justice.
https://youtu.be/lqLhP2GNNYc
Thanks all, can’t wait to get this solved.
-t
Old 03-02-2019, 06:00 AM
I replaced the engine and tranny mounts on my SC a few years back. Started to see some rubbery crumbs at the motor mounts, thought “that’s funny” but then looked a bit closer and found the new bushings had almost completely disintegrated, after only a few seasons. Check your mounts. You’ll get shifting improvements as well if you replace.
Old 03-02-2019, 06:28 AM
Brap
tmaull's Avatar
Any procedures y'all would recommend in terms of isolating the noise? My forum searching didn't come up with much. It didn't seem consistent with chain tensioner collapse.
1980 911SC Coupe 3.4
1995 Miata
2005 Tacoma
2009 Street Triple
Old 03-02-2019, 12:35 PM
If it rattles when you are driving and goes away on you press on the clutch, it is in your gearbox.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-02-2019, 12:52 PM
Brap
tmaull's Avatar
Okay so right now my checklist looks like:
Engine and transmission mounts
Engine tins
Half shafts
1995 Miata
2005 Tacoma
2009 Street Triple
Old 03-03-2019, 06:17 AM
Brap
tmaull's Avatar
So bringing this full circle. Welp - finally fixed it. Noticed that it was only happening in 3rd and 4th. Noticed if i held the shifter over to the left it’d stop. Messed around with the shift coupler for a good bit until it was gone. Got some trans mounts I’ll throw in eventually as well.
Old 03-26-2019, 05:02 PM
