Need some help with a tune-up -- 3.2
Today, on my 87 Carrera, I replaced spark plugs, plugs wires, distributor cap and rotor. The car has been running great but it's been awhile since this stuff was done.
So I start it up and it starts immediately but runs rough at about 900 rpm. I give it a little gas and it bogs and sputters quite a lot, sounding like it's going to stall.
I checked that all the connections are set well, checked the placement of wires in the dizzy, and it all looks good. I start it again and get the same thing.
I used Bosch WR-7-DC+ plugs, Clewett wires, Beru rotor and cap, all from our host.
Any ideas what's going on?
TIA, Ken
Old 03-30-2019, 12:08 PM
I'd check the placement of the dizzy cap. Is it well seated? Inspect the contacts with the rotor.
I struggled with the install of the Beru cap. Didn't feel like it seated well. Replaced it with Bosch after a cap and rotor meltdown.
Re-check your spark plug connections too. I suspect that you're not running on all 6 cylinders.
Old 03-30-2019, 02:53 PM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
The anchors for my distributor cap were very frustrating to seat right. Check there.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002
1988 911 Cab - 5MT - Purchased Used in 2005
2008 Cayman - 5MT - Purchased New in 2007
2014 911/50 - #1173 - 7MT - Purchased CPO in 2014
2019 Macan S - 7PDK - Euro Delivery/New in July 2019
Old 03-30-2019, 03:07 PM
Thanks for sharing your experiences with the dizzy cap -- I will check that tomorrow.
Old 03-30-2019, 05:46 PM
Check your firing order. It's the easiest thing to overlook and the most common screw up.
Old 03-30-2019, 08:50 PM
A bit of silicone grease on the plug boots.
It may be the connection on the plugs, clewett wires need a really good shove to get them to click into the plug.
Old 03-30-2019, 09:28 PM
Brew Master
cabmandone's Avatar
Check to make sure you didn't bump your Cylinder head temp wire loose. I did some work on my car once and bumped the wire just enough to make the car run terribly. I would have swore it wasn't running on 6 but it was running ridiculously rich on 6. I'd tap the throttle and it would stumble and even backfire.
I'm assuming you've gone over your wires to make sure everything is where it should be.
Nick
Old 03-31-2019, 04:17 AM
