al lkosmal's Avatar
plug-n-play?
Originally Posted by mepstein View Post
The kits should be called - plug, tune, play. I don't know of one kit that you can install and drive. Everyone will require tuning.
+1....I've installed quite a few systems and provided many systems to others. I provide excellent start-up files with my systems and this typically ensures that you will be able to fire your engine up, assuming a good install. However.....in my experience, they are all a bit different and all require additional fine tuning, based on actual loading conditions etc. Many of the ECUs provide auto-tuning and it works pretty well.....but still requires the end user/installer to review the results, understand the results and revise and refine. Rinse & repeat until you are satisfied. The beauty/power of these systems is the ability to datalog, review the results and make the required changes to get the desired results. I often have people email me their logs....which i review and then provide recommended changes.........If you're willing to take the time......it typically doesn't take long to develop a basic understanding and get tuned up. Maybe not 100% plug-n-play, but definitely well within the capabilities of most DIY hot-rodders and the difference is worth it..
https://www.youtube.com/watch?v=NzRV7m1DLvM
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-06-2019, 12:22 PM
al lkosmal's Avatar
Excellent DIYer
Originally Posted by Knockdown View Post
Just installed a kit from X-Factory on my 77S, could not be happier with the experience and results. Immediate throttle response and total control over the engine rpm/load range. Plus you have complete visibility of fuel/ignition operation with the data logging capability. Really nice being able to tune your engine from the drivers seat!
PMO ITB/AEM 2.7L Install Notes
thanks for the kind words. You provide an excellent example of how successful these installs can be for the DIYer....
RGruppe #669
Old 04-06-2019, 12:25 PM
Originally Posted by Raceboy View Post
No, t requires IGBT output from ECU or external igniter.
But there are versions with integrated igniter as well.
It is hard to find any info about them, could you provide a number of those with built in IGBT please?
Thank you
Old 04-06-2019, 01:13 PM
Turbonut
Raceboy's Avatar
Thank you
For example VW VR6 (AFP engine) coilpack, part number 021905106. It has integrated IGBT module.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 04-06-2019, 09:37 PM
Thanks for sharing Peeps, very useful info.
Old 04-06-2019, 11:48 PM
Location: behind the redwood curtain, (humboldt county) california
On the fence...
How much weight do you give to:
Initial cost??
Ability: Ignition control - COP, Twin ignition, Sequential/Batch? Turbo?
Up-gradeability?
Support?
Completeness of Kit?? Instructions??
From my initial investigation of EFI, limited to ITB, (because I want the simplicity, appearance and flexibility of ITB), I am leaning towards Al's PMO MS3 system.
Should I go to the Rasant-AEM upgrade?? Is the flexibility/interface/support better???
This is going to be a primarily street,(occasional DE), NA, fun car, 74, 2.7-2.8, Light flywheel/ clutch, LSD; eventually 9.8 CR, E or "equivalent" cams. I would like to be able to do COP or EDIS
I need input on cost versus ease of tuneability, (my time spent with a laptop/and or paying for a pro to fine tune on a dyno??
Ive got no reference point other than the threads here. And I will say that Al has been patient and forthcoming with advice.
I don't need to have a lot of bells and whistles, unless they are going to save me a lot of time getting it dialed in, I.E. AutoTune??
Once again, mired in ignorance....
Thanks,
chris
Old 04-07-2019, 12:18 PM
New-ish 911SC Targa Owner
pampadori's Avatar
"auto tunes" provide you with a VE map that is close enough for most of us. Not sure if they will help with the ignition map which is imo harder to tune than the VE. The real meat of a tune is in the off-throttle fuel cut, acceleration enrichment, idle tuning and engine safety parameters. Your gonna need to spend a few hours minimum dialing these things in and in my opinion these are more important to an easy to drive street car than the VE map is.
If someone was to ask me a condensed thoughts on tuning, I'd say something like this...
VE : get the wot afr near 12.5. Get the cruise afr near 14. Make sure your a little fat where peak torque is. Good enough, move on to the more important ign maps.
IGN maps are best tuned with a knock sensor on a dyno. You can get pretty close by studying the factory maps or the distributor curve map for your motor and mimic that. Add plenty of timing at low-throttle points and cruise throttle range (2-10% tps) for decent mpg and nice torque. You won't burn a hole in a piston running too much timing at 5% throttle. More attention though around peak torque rpm and wot areas of the map. Good enough, now move on to Accel enrichment and decel fuel cut and idle tuning.
For Accel enrichment, it's really an audible process. No lean pops and the motor should sound crisp and quick when you jab the throttle. Learn from others that have similar setups.
Idle- I don't have much experience here. I don't have a iacv on my setup so just use ign timing for the most part.
Decel fuel cut: I think it's best to cruise around neighborhood to set this up. Try a few different setting and see what works best. You'll adjust the map value fuel cut kicks in at, tell rpm it stops kicking in at, and the tps voltage it kicks in at, and the delay time before it kicks in. Pretty simple really.
But I'm pretty sure auto tunes only help out with the VE map is my point.
Buy a setup from Al or Rasant and I feel like their included calibration will get you really close.
Old 04-07-2019, 02:03 PM
This is great information guys!
Thank You!
1981 911 SC
2013 Mini Cooper JCW
2017 GMC K1500
Old 04-07-2019, 04:49 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
Is there a reason not to install knock sensors? There must be as I never read about people doing it, but what is the thinking?
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 04-08-2019, 08:03 AM
pampadori's Avatar
Nope, not a good reason. I have one installed and I know a couple others using the AEM Infinity have them installed as well. Most of us put them in place of the thick aluminum spacer under the throttle linkage bracket near cylinder 3.
When I went to tune on the dyno they actually had a separate knock sensor that they wanted to listen with while on the rollers. It was a "portable" knock sensor that plugged into their dyno so they could graph it along with the other things like AFR and hp and torque.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 04-08-2019, 08:15 AM
