Ova Day
msterling's Avatar
My 88 3.2 Carrera hunted when cold until I installed a Steve Wong chip. You might open the DME and check the fuel optimisation switch. It probably should be set to 0.
1987 3.2 Carrera Motronic DME questions, optimisation?
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 10-19-2019, 08:06 AM
Yes but if was running well before then it could not be the switch. Something else made it idle wrong.
Old 10-19-2019, 05:31 PM
Ova Day
msterling's Avatar
Original factory chip in the DME? Oil fill cap snug?
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 10-19-2019, 05:59 PM
I just opened up my DME box to check the chip, here are the info I found :
DME part # 911.618.111.19
Chip part # 1267355357
I googled the chip number and it seems it relates to the US spec 3.2, mine is a euro 3.2 (930/20), could that be my problem? whats the correct chip for my engine?
Old 10-20-2019, 01:08 PM
Tighten down those intake runner bolts!!!!
Old 10-20-2019, 02:17 PM
Ova Day
msterling's Avatar
Looks like you have the right chip for a late ROW 3.2 Carrera. At one point, my shop retorqued the the intake bolts and my engine sounded and ran better. It must have been leaking some.
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 10-20-2019, 03:04 PM
Bottom line for both my 87 and 89 Carreras was that the initial surging on cold start before the car warms up was dirty (tired) ICVs.
On the 89 (112k miles), which was the car suffering the most, after cleaning once with carb cleaner and a little WD40 the car started without any surging. The second time it surged a few times then evened out. I decided to clean it again and also manually actuate it, in both directions, by applying voltage with alligator clips. In one direction the ICV is not quite as smooth as in the other direction (open/close). I am going to assume that the motor/contacts are getting tired. I will order a new ICV.
On the 87 (134k miles) the car only surges a couple of times before running smooth so cleaning worked pretty well. I must also say ICV on this car is in better physical shape, both cosmetically and operationally. I must conclude that this valve was replaced before I bought the car some 8 years ago.
I hope this helps someone here. I love these forums! Thanks for your help guys.
Old 10-22-2019, 10:31 AM
(man/dude)
Jonny042's Avatar
For the hunting idle at cold start, try backing the idle bypass out a half a turn, before you start it cold, for the next few starts. It should improve a bit. If it does, keep going. I think the loop tuning in the ECU is a bit basic and goes into oscillation if it's asked to do too much.
If it makes it worse, go the other way. When it's warm it will idle the same (as others have noted).
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 10-22-2019, 05:04 PM
Usually backing the bypass out makes it worse and in was the cure for mine.
Cheers,
Joe
87 Carrera
Old 10-22-2019, 08:41 PM
UPDATE : I went a head and ordered a Steve Wong chip and got it installed, surging and hunting went away and it idles smooth and nice, problem solved!
Old 11-06-2019, 12:51 PM
Originally Posted by Nick Triesch View Post
Porsche says to use 10/60 synthetic motor oil in our 3.2’s. How many use that?
I use Liqui Moly 10w60.
Cheers,
Harry
Old 11-08-2019, 12:10 AM
My 3.2 started doing the same thing (hunting idle on cold start), a couple of years back, but settles down to a even idle in 30 seconds or less, and isn't getting worse, so I don't worry about it. I expect there is a minor vacuum leak somewhere. Otherwise runs very well.
1986 3.2 to 3.4 conversion
Old 11-08-2019, 08:02 AM
I would rather be driving
jpnovak's Avatar
Glad you found a work around. However, Wear on the AFM tract as well as dirty idle contact switch can cause this problem as well. Check the AFM wiper if you have any low-speed hesitations.
Old 11-08-2019, 10:00 AM
