Fuchs wheel pattern on 911S 1976
Hi, I have a Porsche 911S coupe 1976 original. I wont to put on it a Fuchs 16x7 in front and 16x8 rear.
That OK, It's a bolt on kit ? ?
this pattern is good ?
16" x 8", ET/Offset 10.6mm, Bolt Pattern 5x130
16″ x 7″, ET/Offset 23.3mm, Bolt Pattern 5×130
Or tell me please the best pattern for the bolt on Fuchs kit
Thanks.
Old 04-06-2019, 10:06 AM
Under the radar
Trackrash's Avatar
The 8" wheels won't fit on the rear, without rubbing, unless you install SC flairs.
The "best" for your car is a matter of opinion. I imagine there will be many here sharing their preference.
Another consideration is the finish. Do you want black or polished pedals?
I personally think the 6 x 15s with polished pedals look the best on mid year cars.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-06-2019, 11:12 AM
Thumbs up
Thank you Gordon,
I will buy a 16 x 7 for front and rear.
I will put a 205/45/16 front and and 225/45/16 rear.
I think it's a better choice
Old 04-10-2019, 10:04 AM
Bill Verburg's Avatar
Thanks.
7x16 Et23.3 Fuchs are fine for the front or rear, if you really want 8's in back the 8x16ET23.3 Fuchs that were fitted to 944s and have 944 part #s can be squeezed in there
Here's are a couple of pics of ischmitz's n/b w/ the 8x16 Et23.3 944 Fuchs w/225/50 x16 tires, 245/45 would be easier to fit and have a lower inertial cost than the 225/50s
Bill Verburg
Old 04-10-2019, 02:10 PM
