Reversing the windshield wiper to passenger side
Went to change over the wipers so they park on the passenger side of my 911 SC 1979.
Got out the 101 things to improve the Porsche Book and read the forums. After trying to remove the blower motor assembly to access the wiper motor I was unable to find what was holding blower still in place. Had remover all air hoses and the screws behind the grill trunk vent still no luck. Reassembled everything and had lunch while reading the forum. One write up said to simply pull the speedo and clock and the nut is right there. 10 minutes later only one nut to remove and it was all done. Thanks Pelican Forums! |
I was going to suggest the same solution, but I see you already found it.
When I did mine I bought a spare straight wiper arm as they are the same length as the bent arms, then I bent it in the reverse direction of the original bent arm. this way I didn't damage my original arm in the unlikely case that I decided to convert back to original configuration. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Wipers.
![]() ^^^^^ Here. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
disband
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
advice: embrace the removal / reinstallation of your frunk vent system. Get to know it well; will make your life a whole lot easier
personally prefer having them on driver's side. in rain (especially on intermittent setting), initial motion pushes water on windshield away from me (driver) and second stroke back further cleans glass -- I'm not too tall (5'8" ) and blades don't really get in my way when not in use either.
fwiw |
Added to which, wiper parking on the driver's side stops water getting pushed up the hood and onto the glass at speed.
'77 S with '78 930 power and a few other things. |
good to know spuggy -- bottom line, the 911 was built from the ground up for the driver's seat to be on the left - not like it's an MG or anything -- good functional reasons for wipers to park on driver's side. Of course, only really matters if it's foreseeable that you'd get out in the rain . . . . (which I do and will continue to do)
Consider taking the wipers off and keeping in frunk only put on when u need them. I don’t drive much in the rain.
87' 911 coupe- guards red/ linen leather Only thing better than owning one is driving it. |
Rescuer of old cars
Early 911 wipers parked on the passenger side, changed to driver around '68, probably due to some obscure DOT requirement.
I prefer mine to park on the right, as the return sweep when parking on left flings water right in my line of vision. I swapped them on my '84, and now that I've tested the '72 in the rain, will need to do it as well. Wipers are necessary in Oregon, unless you are limiting yourself to only driving from July through mid-October.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
One of the best free mods I ever did.
These days I don't even have the passenger wiper arm on the car, just the driver's side arm, parked on the passenger side.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Rescuer of old cars
Uncertifiable!!!
My primary motivation to change the wipers parking position to the right was to have a less obstructed view of those two beautiful fenders and cleavage in between..
![]() Just gorgeous! Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
+1 !
Burnin' Rubber
I like mine reversed. Did this years ago, and forgot until I drove another 3.2
Hardly rains here but when it does, it does, and reversed wipers are fine. No need to obstruct that view! |
Seattle, like most of the Pacific Northwest exercises its wipers.
Parked in front of the driver, the return leaves all this water directly ahead! So with intermittent settings, it's obstructing for the duration of the pause. Arms parked in front of the driver, obstruct part of the view. No matter how insignificant the obstruction is to you, it's an obstruction you can eliminate with very little effort. But I'm also an X-Rain zealot. A windshield wax that causes the rain to run off. At speed the rain is pushed up the windshield! Also, the wax fills little pits and reduces glare. Not affiliated, but a zealot. Michael S. Jackson '78 SC |
Who needs a passenger side wiper anyway?
Registered Minimalist
I did the mod. Tried to access via the speedo and clock. Wiper arm was too hard to pop off from that approach. I couldn't get leverage to pop it off - 43 years of grime glued it on. I ended up taking out the blower to get access.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
