Steering column help
Hi Guys,
I'm taking apart the column, and am having trouble getting these pan head bolts off. I can't get a regular socket on them. Anybody have any tips?
Thanks,
Rob
69 912- back on the road!
69 911T WTB Engine #6195053
72 911T WTB Engine #6122265
https://youtu.be/YZU-NQBTYPM
Old 04-23-2019, 06:09 AM
Those are shear head bolts. the intent it for the head to shear off when the bolt reaches desired torque and then leave a smooth round head so that they can't be removed to prevent theft. You have a couple options, a chisel and punch will usually knock them loose, just place the punch at the edge of the remaining head and tap with a hammer in the loosening direction. Another option is to slot the head with a Dremel or hacksaw blade and use a large flat blade screw driver to remove them.
Old 04-23-2019, 08:40 AM
Makes sense. Thanks for your great explanation!!
Old 04-23-2019, 09:23 AM
