Senior Member
Alternator Wiring Help
Here is what I know about alternator wiring: If you get it wrong, then wires fry. I hope to get it right. Here are two pics and here is my belief: The fat red wires go on the "+" side (upper left). The tiny blue wire goes on the "-" side (top right), next to the matching blue wire which is part of the alternator. The brown wires go to the lower terminal which, similar to the blue wire, is also on the plate marked "-". Correct?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I just did mine few weeks ago. Here’s a picture of my old one from 83 sc when I pulled it out.
SC Last edited by Leebag; 04-28-2019 at 01:51 PM.. |
Don't forget the ground strap.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
The pixies inside don’t care about the color on the outside. If it were me I would verify with an Ohm meter the terminals were connected to each other correctly regardless of color. There are some good wiring discussions on this board with diagrams.
1966 912 to 2.7 Frankencar |
Senior Member
![]() Okay, now I need expert help. I (think I) hooked this alternator up the way Leebag did, and the way this diagram shows. Two problems: The alternator light is on and the system is not charging. What can be wrong. Can I reverse the smaller wires (not the fat red ones which are on the + buss) which are on the negative ( - ) 'buss' and perhaps that is the problem? It is possible the wires may have gotten crossed during this project (wrong wires temporarily connected to the poles), but there are no burnt wires and there was no burning plastic smell at any time.
Did you read the note regarding the resistor addition ....if the charge light doesn't go out?
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Senior Member
Update: False alarm. In installation, I had pinched a wire against the alternator body, grounding it. The diodes and voltage regulator survived. I found a very good alternator/starter repair shop in Ruston (part of Tacoma) very close to the ferry dock. Couple of old fellows with REALLY good attitudes. Sound Starter and Alternator Repair. I said I may bring my spare starter to them. They said okay, but also that these old Bosch starters are very well made and do not often need rebuilding. I suppose they also need to understand these old 911s tend to have several hundred thousand miles on their clocks.
Sup,
I'm glad you found a real alt/starter repair shop. The good ones seem to be disappearing. There used to be one up here in the North end - Lynnwood Auto Electric. The old guy there used to have a shop either close to or next to where John Walker was working at the time, and remembered him. When I was working on my 911 alternator, I took it there. I set the alternator on his desk, and said Porsche 911 - no hesitation . He took me upstairs while he tested the alternator. His workshop was right out of a Boris Karloff movie of Frankenstein. Crazy electrical panels of dials and switches - but he fixed my alternator. I'm not sure what I would do now (Lynnwood Auto Electric is long gone). Maybe I'd go to Ruston and check out your repair place.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Functionista
Usually a quick process of elimination on three wire alts.
Red to large terminal Blue to post with insulated washer Ground to last one left Also ground alt to engine case
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
