Mrdi's Avatar
Deep cycle Optima
I have a deep cycle Optima
65 Amp hours
900 marine cranking amps
W/ an AJ USA adapter plate
bought it last year for the 911, but ended up changing out the alternator
didn't realize it was deep cycle marine till recently
Will that be an OK batt for an 88, 911?
Old 03-19-2003, 06:07 PM
Cool Re: Deep cycle Optima
Probably not for the long term.. it should gradually get weaker and weaker.. you can then recharge them with big current/not trickle.. it kinda loses its max voltage over a short time.. maybe 6-12 months.. maybe Optima has a site for more info
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-19-2003, 06:38 PM
tiorio's Avatar
Yeah, not really the optimum battery for this application. The way the plates are set up the deep cycle battery is used better to be really discharged before being recharged, the typical car battery is better suited to providing higher amperage over a short period and then being recharged. The plates in your deep cycle battery will probably shed rather quickly and you'll loose the high-amperage output you need to start.
-Todd
'89 930, '97 TLC (Toyota Land Cruiser), '96 T-100pick-em-up
'95 BMW R100 GSPD (gone but not forgotten), '07 BMW R1200GSA
Old 03-20-2003, 10:22 AM
Mrdi's Avatar
Which is the ideal optima 88-911
Old 03-20-2003, 10:36 AM
Cool
I have no problems w/my Red Top Optima..
but Jack Olsen has a better act going w/his battery.. give him or Tyson a PM for the mfg. and model
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-20-2003, 11:01 AM
yes, red tops are good for cars. blue is good for boats.
other than that I think they just make side post terminals or top mount.
I'm often wrong about lots of things though. if you go back to where you bought your marine optima, it should become apparent. they are pretty cheap at costco. that's where I got my red top!
Old 03-20-2003, 11:04 AM
RSR.guy's Avatar
I run a similar Optima in my BMW (which only gets driven a few times a month). It's been installed for over two years with absolutely no problems. As far as I can tell, it's relatively bulletproof.
Cheers, Chris
Old 03-20-2003, 11:22 AM
Mrdi's Avatar
RSR are you running a
Blue marine optima in your BMr ?
Mrdi
88 Carrera G50
Old 03-20-2003, 11:38 AM
NYSCAR's Avatar
Send a message via AIM to NYSCAR Send a message via Yahoo to NYSCAR
Search the archives, lots of Optima info. The one Jack has I think is a Stinger, small and powerful. Got mine at www.sounddomain.com (yes it was targeted for the monster boom stereo guys).
Brad
73 911S Coupe sold
Old 03-20-2003, 01:08 PM
