Question Neatrix- Glue or Grease?
Hi,
I will hopefully get my Neatrix bushings from Pelican tomorrow and put my rear suspension back together, but how?
I have read many different thoughts on installing the Neatrix bushings, some people glue them to the spring plates whereas others just grease them up really well and bolt everything together. Is one way better than the other? I know that Porsche vulcanized the bushings but what's the consensus on Neatrix bushings?
Thanks!
Neil
'73 911S targa
Old 03-21-2003, 03:36 PM
marcesq's Avatar
Lightly greased, no problems
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 03-21-2003, 04:29 PM
SK SK is offline
SK's Avatar
I lightly greased mine as well. It has been a year and no problems here either.
Old 03-21-2003, 06:19 PM
mm86911's Avatar
Lube 'em up and no problems - been in my car for over a year with no noise.
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 03-21-2003, 07:39 PM
Neil,
I am wondering if you got the last set from our host. I am still waiting mine. Althogh I was told more are coming in and they will ship. How did you end up taken the old ones off?
Bob 80SC
Old 03-21-2003, 07:46 PM
autobonrun's Avatar
My Neatrix arrived today.
What do you use for lubrication of the bushings. All I have in my garage is Swepco Moly 101 grease. Will this work or is it petroleum based and not suitable for rubber?
Old 03-21-2003, 08:17 PM
Bob,
I've been waiting for a while as well. They were supposedly sent yesterday and hopefully I will get them tomorrow.
I followed Chuck Moreland's instructions which you can find in the Pelican Parts tech article area (or click here ).
Since I didn't have a vice, I used a c-clamp to hold my spring arm to my apartment balcony and started cutting it up like Chuck did. Wasn't nearly as bad as I expected. I sanded off what I couldn't cut off.
Auto, are there any instructions with the bushings? Are you going to glue them or just lube them up really well?
Neil
'73 911S targa
Old 03-21-2003, 08:50 PM
Chuck Moreland's Avatar
Glue. The rubber bushings are meant to deform, not slide.
I've learned the (really) easy way to get these off. Use a torch to heat the spring plate tube from the inside, under the bushing. Heat until you see a fair amount of rubber smoke.
Then run a razor knife around the flat plate to free the rubber. With just a little poking with a screwdriver the bushing will come off in one piece.
Never use petroleum based grease. It will destroy the rubber in short order.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-21-2003, 09:49 PM
billwagnon's Avatar
Is there anywhere to buy the 4-bolt plate that goes over the end of the swing arm at the torsion bar (I think it may be called a torsion bar cover).
Mine are lightly corroded on one side (inside) and should probably be replaced.
Old 03-22-2003, 03:29 AM
Irrationally exuberant
ChrisBennet's Avatar
Pelican has them. Part # A-333-153-00 At only $15 each it isn't worth restoring old ones.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-22-2003, 04:35 AM
mm86911's Avatar
Chuck - does it really matter whether they are glued or lubricated?
I used a thick, silicone-based lubricant on both front a rear bushings (cut channels into front polys) and have zero noise for over a year now.
Only wish the Elephant front bronze bushings were available a year ago.
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
Old 03-22-2003, 05:23 AM
The product does ship with glue, so that tells you what the manufacturer thinks. Why they can't throw in a page of instructions to explain this stuff is beyond me.
I believe they will last longer if glued. With glue, there is no slippage therefor no wear. The rubber just deforms then bounces back like factory stuff.
If you opt to grease, Silicon is the way to go. However I find silicon grease doesn't last that long. In time you will end up with little-to-no lubrication since there is no provision for relubrication after installation [subtle plug on]unlike Elephant Racing bronze bearings which have built in grease fittings[/subtle plug]
Old 03-22-2003, 08:10 AM
What can be done to the spring plates to bring them back to orginal condition? Without sounding anal, I would like to clean them up prior to putting the new bushing on. I was thinking of bead blasting them clean them and painting, what is everyone's ideas and what has others done? I want to accomplish this using the tried and proven method, as I am not into looking for a new wheel design.
Bob 80SC
Old 03-22-2003, 08:17 AM
I just sent out two pair of spring plates for zinc dichromate plating. It's a gold tone similar to the original cad plating. I'll have them back end of next week and will post some pictures for you.
That is your best option if you want something that looks factory.
Old 03-22-2003, 10:30 AM
SK SK is offline
SK's Avatar
Bob, I did exactly what you wrote. They look great, and it was inexpensive.
Old 03-22-2003, 11:02 AM
autobonrun's Avatar
I plan to follow what you guys are doing in an effort to replicate factory design. Parts that are molded together will be glued. Parts that look like they will rub together will be lubricated. I'll see if the Moly is petroleum based. If not, I'll use it, as it should stay in place longer.
Old 03-22-2003, 11:05 AM
I have a couple more questions.
There was some surface rust where the bushings sit inside the torsion tube. I cleaned up the area with a wire brush and sanded down any high spots. Would it be ok to paint the newly exposed metal with POR-15?
I didn't order any silicone grease thinking I could get it locally. I have since found out that silicone grease is very hard to find. Short of ordering it from Pelican, what kind of stores carry it? Home Depot doesn't have it nor do any auto parts stores. I have some silicone spray, but that seems very temporary.
Thanks,
Neil
'73 911S targa
Old 03-22-2003, 11:32 AM
NAPA carries silicone grease.
Old 03-22-2003, 12:13 PM
The silicone grease NAPA carries is called "Sil-Glyde". It's often used for brake calipers.
-Chris
Old 03-22-2003, 02:17 PM
Chuck,
Where did you send them for plating and how much did it cost?
Bob 80SC
Old 03-22-2003, 02:37 PM
