Beginner question, flywheel on 3.6 conversion
My 911 has a 3.6 conversion (in a '78) mated to a 915 transmission. It's a 964 (out of a '90). Unfortunately I cannot ask my uncle, who build this car, any questions about it as he passed, and I have a TON of questions
![]() It has a lightweight flywheel. Is the flywheel specific to a 964, or the tranny, or is it specific to the "shortened bell-housing" conversion? I can't seem to find an answer. Thanks for any help.
02 C4S '78 911 '92 911 Cabriolet (Passed) |
Under the radar
Probably a custom flywheel. https://patrickmotorsports.com/collections/patrick-motorsports-parts-kits/products/flw-22536dmefw-pmp
You don't have a shortened bell housing, that mod is specific to g50 transmissions
Thank you Bill, so it could be any LWF for a 964 as long as it worked with a 240mm clutch?
A lwf for a 964 would still have a 240mm friction surface for the clutch and would likely weigh ~12# vs the ~10 for yours.
We have the 3.6/3.8L 964 engine with the 915 and a conversion flywheel . . . 5 years racing (100+ hours and one engine refresh) and clutch is still good . . . Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
Since the conversion, the car had a stalling issue. I am working with Steve Wong to solve the issue (and I think we can) but I like to have a backup plan. Since I am not going to track it, I could throw in the towel and uninstall the LWF.
Wish you the best, Regards,
There's more than one way to skin a cat, LOL. Back in '92 I put an
'89 964 into my '80SC. In '89 the 964 motor came with a single 240mm light weight flywheel, not the dual mass heavy one. There were no conversion flywheels available back then, so I took the stock the 964 light weight flywheel to my local machine shop and had it redrilled for a 915 225mm pressure plate. It all worked out perfectly. I have never had any of the light flywheel problems in the last 27yrs. Back then you had to be quite creative with a 3.6 conversion, as there were no "conversion kits" on the market, but it all worked out. I also retrofitted a stock on engine oil cooler to the 964 motor, and with the combo of the on engine cooler plus a Carrera front cooler and fan, she runs cool as a cucumber. By the way, that '89 single mass 240mm flywheel is still available from our host.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 06-04-2019 at 10:26 AM.. |
Thanks for the info, uwanna, Roy, and Bill. I have never worked with clutches or flywheels (yet) so this is very helpful.
