Euro ride height
Just found this 74 911 on craigslist and thought I'd post it since nobody seems to know what euro height actually looks like:
https://images.craigslist.org/00707_gMu9LFfjZqZ_1200x900.jpg
By the way, if anyone knows how to embed a craigslist image to this post, let me know. All I know is how is to copy and paste. Better yet, if you could fix it for me, even better.
Cheers,
Joe
Old 06-09-2019, 07:52 PM
Actual factory Euro height is higher than what people in the US implement when they say Euro height. The actual spec is well defined:
Americans drop it below that for looks and, IMHO, it is not a good thing for street driving.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 06-09-2019, 09:13 PM
HarryD's Avatar
Lots of threads on the topic. This one seems informative: Euro ride height question
Do a search using the terms ride height euro fender. The correct way is above. If you have stock size tires measuring the fender height is a short cut.
No matter how you go about this, an alignment and corner balance will be needed if you change your ride height. You also need to verify you have sufficient suspension travel and your steering geometry is correct.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-09-2019, 09:26 PM
HarryD's Avatar
If done properly, you can have a lowered car and a decent ride. The devil is in the details.
Mine is below “euro” height but the shop that did it ensured I had adequate ground clearance for city streets, my steering geometry was correct and my suspension travel was adequate.
Harry
2020 MB E350 4Matic
Old 06-09-2019, 09:29 PM
Bill Douglas's Avatar
The most important thing is to look good. And that car doesn't look good.
The correct stance thread gives a good indication of "Euro ride height" and below.
Old 06-09-2019, 10:16 PM
HarryD's Avatar
It may be that the tires have shorter than standard sidewalls. Factory sizes are per the factory owner's manual from 1974 165HR15, 185/70VR15 or 215/60VR15. A 205/60-15 will work as well.
Originally Posted by HarryD View Post
My '73 with 205/60-15's and lowered:
Same Tires, Before Lowering:
With 205/55-15's and lowered:
Also, here, fixed (if you want to see what I did, reply to this post with quote and look what bracketed the url or in the message window above where you type there is a picture icon, hit that and insert the url):
Harry
2020 MB E350 4Matic
Old 06-09-2019, 10:26 PM
Hi Harry,
I like what you did but still cannot figure how you did it! You must be a magician.
Joe
Old 06-11-2019, 09:42 AM
I know it's a matter of personal taste, but I really like the looks of the factory euro height:
Old 06-11-2019, 09:53 AM
Registered Minimalist
75 911s's Avatar
That 74 just needs a skid plate, some knobby tires and lights all over the hood and it's ready to traverse the streets of LA
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-11-2019, 09:54 AM
Bill Verburg's Avatar
The only cars w/ raised suspension were the US versions from '75 to '83(look for front height ~99mm+/
You'll also note that the factory RS 3.0 went down to 143mm+/- and the same year RSR was @ 160mm
Bill Verburg
Old 06-11-2019, 11:36 AM
I think the reaction to Louise Piech's Turbo ride height (which is true correct Euro ride) is due to the US mania on slammed cars.
Old 06-11-2019, 11:42 AM
HarryD's Avatar
Originally Posted by stlrj View Post
Hi Harry,
Joe
Thanks goes to Jeff Gamroth and his team at Rothsport Road and Race.
Harry
2020 MB E350 4Matic
Old 06-11-2019, 11:45 AM
Like this one in the streets of LA:
Old 06-11-2019, 12:05 PM
Like this?
OK Harry (Houdini) , I bet you can you flip it right side up...show off!
Joe
Old 06-11-2019, 02:10 PM
HarryD's Avatar
Joe
Darn iPhone Picture!
Like this?
Harry
2020 MB E350 4Matic
Old 06-11-2019, 02:19 PM
HarryD's Avatar
And this?
Harry
2020 MB E350 4Matic
Old 06-11-2019, 02:22 PM
Yah ...you da man! No question!
Old 06-11-2019, 04:12 PM
