68 911 name this part please.
300 mm long pinch weld small. I only have one but I'm sure its a pair.. B pillar on rear pop out window ???. Or ?? Its not the pinch weld on the rear window for the roof lining. I have that
I can't find it anywhere on the parts list Thanks Lyndon
it goes inside the front trunk right hand side is a hole for the hydraulic headlight adjuster to go inside.This just wraps on the edge..here...
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
On a 68 911 ??? Hydrolic headlight adjuster??
Lyndon |
no , all 911 have this hole..that is all..and if you will be in 1968 in France for example you will have the adjuster there..
Ivan
Ok. Thanks I will have a look
Lyndon |
I think that is the edge protection for the pop-out window...
https://www.pelicanparts.com/More_Info/90154342300OEM.htm?pn=901-543-423-00-OEM&bt=Y&fs=0&SVSVSI=911M
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
al.. you might be right
Ivan
Yep rear pop out. Goes on the B pillar.
Perfect thanks. Lyndon |
