68 911 name this part please.
300 mm long pinch weld small. I only have one but I'm sure its a pair.. B pillar on rear pop out window ???. Or ?? Its not the pinch weld on the rear window for the roof lining. I have that
I can't find it anywhere on the parts list
Thanks Lyndon
Old 07-07-2019, 02:11 AM
proporsche's Avatar
it goes inside the front trunk right hand side is a hole for the hydraulic headlight adjuster to go inside.This just wraps on the edge..here...
1985 911 with original 502 191 miles...808 198 km
Old 07-07-2019, 04:30 AM
On a 68 911 ??? Hydrolic headlight adjuster??
Lyndon
Old 07-07-2019, 04:34 AM
proporsche's Avatar
no , all 911 have this hole..that is all..and if you will be in 1968 in France for example you will have the adjuster there..
Ivan
Old 07-07-2019, 04:43 AM
Ok. Thanks I will have a look
Lyndon
Old 07-07-2019, 04:45 AM
al lkosmal's Avatar
I think that is the edge protection for the pop-out window...
https://www.pelicanparts.com/More_Info/90154342300OEM.htm?pn=901-543-423-00-OEM&bt=Y&fs=0&SVSVSI=911M
RGruppe #669
http://www.x-faktory.com/
Old 07-07-2019, 12:12 PM
proporsche's Avatar
al.. you might be right
Ivan
Old 07-07-2019, 12:25 PM
Yep rear pop out. Goes on the B pillar.
Perfect thanks.
Lyndon
Old 07-07-2019, 01:56 PM
