Stranger on the Internet
Starter not turning
The short story is when I turn the key, the starter does not engage...no clicking, no dimming of lights, nothing.
Long version is, everything was ok UNTIL I TOUCHED SOMETHING. I relocated the battery from the smugglers box back to its original location, and I changed the spark plugs. Car is a 78 SC, turbo. As such, it has EFI, and nothing is anything like it was when it left the factory. 14 pin connector is long gone. I figured maybe I knocked a wire loose; can't find anything. I have battery voltage at the starter. I have continuity from 50 at the switch to the 50 terminal at the starter. I assume the 50 terminal simply provides power to the starter solenoid, and it internally makes a switch to rotate the started motor. I put in a new ignition switch I had lying around; no change. Can I simply jump out 50 to 30 to test the started solenoid? I am thinking I may have a starter issue. Again, everything was OK, UNTIL I TOUCHED SOMETHING. ![]()
Patrick E. Keefe 78 SC |
ROW '78 911 Targa
Yes, jump across to engage solenoid to see if if it works
ROW '78 911 Targa
Check for 12 v from start switch when in start position at short yellow wire coming out from 6 pin connector on trunk side of firewall.
Thanks Dennis. I will check for voltage there, on the trunk side.
use a test light.
compare the light from the battery voltage to the starter signal. they should be the same it takes a lot of current to pull in the solenoid. you can have 12v but there may not be enough current due to resistance somewhere along the line. how is the ground connection at the front, is it a good connection between the battery and the body,
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Jumped across the solenoid engages the starter and it turns normally Ground connections are OK I’m going to run a jumper from terminal 50 at the switch to terminal 50 at discharge her and see if it changes anythingj.
Edit: Works fine when I jump it Last edited by patkeefe; 07-09-2019 at 11:56 AM.. |
the starter is fine...start with the basics...the main problem is usually the ground straps between the trans.and the body.Loosen the 13mm wrench nut clean it and see. Let us know..
this one........... Ivan ![]()
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
ROW '78 911 Targa
Pat, replied to your PM.
Give me a call.
Brew Master
Had something similar to my BIL's car while vising him. Ended up being the yellow wire that goes to the starter solenoid coming loose in the connector in the engine compartment.
Nick |
if he jumped from term 50 to 30 and it worked fine, then its not the ground strap.
ROW '78 911 Targa
After talking with Pat, per his testing, it is a fault in the wiring from front to back of car or in the ignition switch harness. He doesn’t have time to fix it for a while. Other priorities.
Brew Master
Did he test the yellow wire that goes from the plug in the engine compartment to the starter solenoid? I'd start by pulling the plug in the engine bay and testing continuity from plug to solenoid end then check voltage up to that point.
Nick |
