Born to Lose, Live to Win
ramonesfreak's Avatar
Fuel gauge never shows full
See below pic. This is as full as it shows. Is there a way to adjust this? New fuel sender?
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 07-13-2019, 05:41 AM
Titanium User
Remove your level sender and check if the float is getting hung up. You may be able to fix it.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 07-13-2019, 07:02 AM
Ok I’ll try that. Thanks
Old 07-13-2019, 07:10 AM
The fuel sender for my 86 is inside a tube with tiny little holes for gasoline to get in and out. I think the idea is to dampen the fuel sloshing that the float has to react to. Anyway, the tiny holes on mine were partially plugged with sediment, which made the gauge reading often pretty inaccurate. If you pull the sender out, have a look at the little holes on the side and bottom of the tube. If I ever do this job again, I think I might run a drill bit through the holes and open them up a wee bit.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 07-13-2019, 07:27 AM
Ok. Thanks for the info.
Old 07-13-2019, 09:54 AM
