Born to Lose, Live to Win
Fuel gauge never shows full
See below pic. This is as full as it shows. Is there a way to adjust this? New fuel sender?
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
Titanium User
Remove your level sender and check if the float is getting hung up. You may be able to fix it.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Ok I’ll try that. Thanks
The fuel sender for my 86 is inside a tube with tiny little holes for gasoline to get in and out. I think the idea is to dampen the fuel sloshing that the float has to react to. Anyway, the tiny holes on mine were partially plugged with sediment, which made the gauge reading often pretty inaccurate. If you pull the sender out, have a look at the little holes on the side and bottom of the tube. If I ever do this job again, I think I might run a drill bit through the holes and open them up a wee bit.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Ok. Thanks for the info.
