Alternator Problem?
I have several problems with my 2.7 911
-something is slowly draining my battery down.
-when I first turn the key to the on position before cranking the car the tach needle swings wildly all the way to 6000 to 7000 on the tach. This is before the car is cranked and running
-Once cranked and running the generator light glows but goes out after rpms are above 1000 on the tach like it should
- at night however the generator light stays on even at higher rpms and glows dimly all the time. Do I need a new alternator?
Old 07-20-2019, 09:55 AM
76 911S Targa
It sounds like the diodes are passing current when they should not. In other words, at least one diode in your alternator has failed. You can remove the alternator and have it tested. As for the tach, check your point gap. The point gap may be too small, should be .012 inch..
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 07-20-2019, 10:15 AM
I would start with a new voltage regulator and if that works, think of all the money you saved instead of a pricey alternator!
Old 07-23-2019, 01:57 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Or you could troubleshoot.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 07-24-2019, 08:05 PM
