Discseven's Avatar
Wiper slack-knock fix
I think this knock is due to slack in knuckles but am not sure. Whatever, sound is unpleasant at best. (This is not wiper blade flopping.) Putting tension---not much---on operating rods eliminates knock. I quick-epoxied hook onto backside of dash and used a rubber band. Should be regarded temp fix as it's possible that tension here wears parts out faster than if they were left alone.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-01-2019, 11:22 AM
Designer King
Paulporsche's Avatar
Something else to check, Karl: I had a thunk sound every time the wipers were at either end of a cycle. Turns out my motor was loose from its bracket. 1 bolt was just hanging on. I tightened it and added 2 replacements and now the wipers work quietly.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-01-2019, 12:36 PM
Discseven's Avatar
^^^ I'll take a look at that... thanks Paul.
Karl ~~~
Old 08-02-2019, 02:08 PM
Designer King
I was able to access the motor, bracket and bolts via the dashboard gauge holes.
Paul
Old 08-03-2019, 08:31 AM
