1980 lambda-CIS: Coast or go to neutral?
Hi,
I have a fairly good understanding of the lambda-CIS on my '80 US-spec SC, however I can't make up my mind if it's better to coast or go to neutral when going downhill (if fuel-saving is the priority).
Assumption #1 – Coasting is better:
  • For: Since the engine is being run by the wheels it will consume less fuel due to system sensing there is no throttle input and using the freq.valve to down-adjust the fuel-flow.
  • Against: The system is not clever enough (as more modern systems are) to sense the above and the increased revs of the engine will draw the fuel-meter plate up resulting in more fuel being injected.
Assumption #2 – Neutral is better:
  • For: The closed throttle plate will limit the lift of the fuel-meter plate thus giving the same amount of fuel injected as when idling and you get the benefit of keeping the speed up due to lack of engine braking.
  • Against: The engine needs to consume fuel to keep going at idle instead of being ran by the momentum of the car.
Anyone care to enlighten me what is correct? I also realise that the benefits are small so this is more out of curiosity than anything else.
Cheers!
1980, 911 SC. Ex-US car in Sweden since June 2010. Insta: @911scowner
Old 08-06-2019, 06:05 AM
