Insert Tag Line HERE.....
1. PDK (new car..lol )
2. C2T engine into SC 3. 3.6 into '72 4. GHL exhaust 5. Wevo shifter Hard to pick one that stands out after that as I upgraded suspension/brakes/wheels, etc. on all of my early project cars..
Marc |
C2t and a 3.6 I hate you.
Another vote for Rennshifter. Probably the most satisfying bolt on modification for the time & money.
Cup holder might be second on the list, haha |
Senior Member
Getting rid of the A/C system and the fan assist system on the left side of the engine feeding the heat exchangers. Makes it so I can see and reach both sides of the engine, and also improves the heating when needed.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
The important thing, you made the car what YOU want, not what I think is right. That is what matters. I will admit, it does look better. But I personally prefer function over form. YMMV.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Senior Member
Agreed. In the pacific northwest, "function" means decent heat and virtually no reason for A/C.
I like this question.
Lightening the car: A.C. delete, side skirt delete, rear seat delete. Turning the gages was a must with speeds on the Autobahn, 80-100 Turning the gages was a must can actually see the tachometer what is happening speed-wise. (free) Would like to reduce more weight eventually. Sometimes I miss having A.C. on hot days.. Not expensive: I love my MoMo Prototypo nice size /some dish. Sparco front seat has been great to keep me planted and optimal position. ( got these things used and reasonably priced ) Some expense: Elephant after-market stuff: I am hoping my suspension re-fresh (almost done!) is my favorite mod ..lowered w/ new rubber everywhere, new mounts etc.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
a.k.a. G-man
I use a Tekniq quick release on a momo hub. My steering wheel (Prototipo) is about an inch closer now, more room between upper edge of the dash and steering wheel. And it also is a good anti theft device.
Сидеть, ложь, Переворачиваться |
a.k.a. G-man
My car sounds Harley like at idle. To be honest, I prefer a less lopey, more fluent, more modern sound. I thought it was due to the SSI’s and M&K (regular dual out). It makes sense that the 964 cams have something to do with it... Anyone know how to make it a bit smoother sounding?
a.k.a. G-man
My car is in the shop now.
I asked to cap the right side of the muffler to quiet it down a bit. Hopefully the lopey idle will be less, but I’m not very sure. I prefer to keep the M&K because it is such a high quality, lightweight muffler. But you make a good point. (And Dansk is not that bad either)
1988 Carrera
An extra condensor for the A/C.
SW Chip 964 cams these things make me smile every time i drive it.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Location: behind the redwood curtain, (humboldt county) california
Moving forward...
My favorite thing I've done to the car is putting it on a twin post rotary lift!!!!
The best upgrade was to dump the AC and add the Carrera cooler. When I'd visit my dad in Santa Barbara the 74 had absolutely scary oil temps and almost no oil pressure. Looking forward to getting the car back on the road, upgraded suspension, quick rack, adjustable rear Carrera bar, RSR flywheel, 6 pound alum clutch, Rennshifter,stomsky, duck, recovered sport seats, new brakes and MK 2-2 sport and.....stock, (150 hp) 2.7 Not sure which of the goodies is going to get the "favorite" tag. Still pushing it at 71 - can't wait to get it to thunderhill. chris |
1972 911T I've had for 20 years with 234,000 miles
Front fender full sized oil cooler Removed right front battery box to improve airflow over oil cooler Took my 'one battery' and moved it to the smugglers box Raised Bilsteins to lower the front Replaced stock front brakes with SC calipers 20% larger Fiberglass hood Recaro seats Wevo shifter Removed half of door panels Australian Superlite wheels 15 x 7 about 1.5lbs heavier than Fusch Aluminum trailing arms Fiberglass ducktail 1981 3.0L twin plug built to turn 8500rpm 9.5:1 245 crank hp @ 6900rpm and 227 ft/lbs torque @ 4800 rpm, bullet proof! 40 mm webers opened up to 42mm Hyd chain tensioners 10 lb M&K muffler 2 in 2 out Corner balanced: weight 2210 with half tank fuel Purrs like a kitten or screams like a banshee.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Caveman Hammer Mechanic
x3, along with the Rebel Racing suspension pick up bushings and monoballs everywhere.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Replaced my injectors with the new four hole EV6 Bosch injectors (0-280-155-703) on my 87 Carrera resulting in amazing low end torque.
Over the last 22 years, I replaced and upgraded my 87 Carrera with the most common parts discussed in the forum.
The most noticeable improvement, however, was to acquire Sal Carceller MAF kit that consisted of a complete rewrite of the performance chip in a customized DME, A much accurate air flow meter (solid state) and matching cone filter. a modern set of efficient fuel injectors and all of the above work in harmony together to provide smooth performance of the engine, precision and reliability. |
My '79 SC had a broken headstud problem
![]() Wow. A completely different engine. The '79 ROW had some torque and went well. But the '82 engine with subtle mods goes like an over-reved sewing machine. Not as much torque but it revs out very smoothly. More power definitely. It's quite happy with 6,000 RPM gearshifts from second gear upwards. |
Interesting, I would think you'd rather have the heads from the 79 on that engine.
Grappler
My favorite upgrade? Those bits hanging below the rear bumper.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
