Engine tin interchange?
I should know this, and I think the answer is no, but do 2.2 and later engine tins interchange?
Is there a guide anywhere?
Thanks!
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 08-17-2019, 12:35 PM
Walt Fricke's Avatar
I believe the tins from 1964 (2.0s, anyway) through 2.7 interchange. When I tried to use 2.7 tin on a 3.0 I had to do some modifying, as those tins are different in how the spring clips hold them. You could check parts manuals (available from Porsche on line) to see where there are different part numbers.
Bruce Anderson's book shows how to modify early tin for better cooling, but you don't need that for fit and to get the spring holders to work.
Old 08-17-2019, 03:17 PM
Thanks Walt
911 w/ 3.2
Old 08-17-2019, 09:00 PM
