sp_cs's Avatar
T-bar or ARB issue
I experienced a strange vibration when driving home last night - approaching 70mph, on a LH corner, accelerating into 5th. Felt a thumping under the driver seat (underbody) for 2-3 seconds, which I never felt again for the remaining 40 mins home.
Viewing side to side, i now notice the OSR arch to tyre gap is bigger than the NSR by 5-7mm - OSF and NSF look as it was previously.
IIRC, if the OSR is high, its means a problem at the NSF, but both front looks ok?
Both rear t-bars were replaced with good used items back in 2011.
Prior to checking RH this morning, i took it for a spin last night up to the local 50mph speed limit - nothing untoward heard or felt when steering in both directions at 50mph
At standstill, could a failed ARB Mount cause ride height issues, or is it more likely to be t-bar? I tried wiggling the rear arb but couldn’t budge it at either end.
Wondering if I can drive it safely 5 miles to the specialist. Would a failed t-bar show up with a more drastic height difference?
Thanks all.
Shirish
1987 Carrera, Granite Green
Old 08-17-2019, 04:14 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Thanks all.
Jack up the car, safely. Climb underneath, with flashlight, inspect the ARB mounts. Failure will be evident. Mine were creaking and groaning on slow off camber inclines, it stopped, did the above and the left side was ripped clean off the car. Buttload of grinding, fitting and welding the "new/old" Wevo RARB consoles.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-18-2019, 11:01 AM
sp_cs's Avatar
Thanks - so a failed ARB mount will affect ride height?
I have Wevo mounts fitted.
Shirish
Old 08-18-2019, 02:33 PM
Diss Member
Quicksilver's Avatar
No. Swaybars only effect the car when the car is leaning.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-18-2019, 03:43 PM
Racer
winders's Avatar
Not true. Unless you have adjustable drop links, the sway bars will add pre-load. Also, once you add sway bars, the suspension is no longer fully independent. So a bump felt on one side of the car transfer some force to the other side of the car.
No leaning required for either effect.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 08-19-2019, 01:57 AM
sp_cs's Avatar
I have adjustable drop Rennline drop links fitted.
Drove the car back to storage today, approx 10miles of mixed roads. Nothing untoward noise wise, but found the NSR slightly higher than yesterday (just get my finger into the gap, impossible before). NSR still slightly lower than OSR
Shirish
Old 08-19-2019, 08:06 AM
Walt Fricke's Avatar
Perhaps the ride height adjustment on the spring plate got loose?
Are you using high pressure gas shocks? Those raise the ride height when swapped in without making a ride height adjustment, so if one lost pressure you'd expect a sag on that side.
Old 08-19-2019, 01:09 PM
sp_cs's Avatar
Someone else has suggested the same, although I see no witness marks suggesting things have moved there.
Using standard Boge shocks, with +1mm bigger ARBs, Wevo arb mounts and Rennline droplinks.
Strange how the NSR has suddenly raised itself.
Shirish
Old 08-20-2019, 10:58 AM
