Mr. Merk's Avatar
Originally Posted by Driven97 View Post
The "new" A052 (200tw version) is said to be pretty good in the wet. There are correct height 16" options, too. Upper end of the trackable street spectrum. As in, I can run these on the track if I want.
The r888 / R is the streetable track. As in, I can get away with driving to my track day if I want.
The best part about those is that they have them in 245! Since Bridgestone left the party we've had few options. When I was still on narrow wheels I ran the Star Specs II (2015) and then the RE71R.
How do the A052 compare to those?
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 10-05-2019, 06:28 AM
Haven't run them myself, but friends say they're similar to the Rival S but better in the wet and more tolerant of heat.
Matt - 84 Carrera
Old 10-05-2019, 06:45 PM
Advan AO52
I got a set of Yokohama ADVAN A052 for my '86 Carrera to take to the track.
205/55-16 and 245/45-16 on 7" and 9" rims.
Granted, I need more tire in front (this is what I've always used), but i think these had better bite than the RE-11 that I had been using for years. And...... they hardly squealed at all. My Re-11s always squealed weather new or old.
It was really strange that for half a day I was perplexed as to what was going on because I was way off. Eventually, I figured out that I wasn't pushing so much as before and thus didn't need to turn the wheel as much (more bite). I was sort of making tiny corrections all the time (first half of the day) because I was turning in too much - that's the way it always was and I was used to it with the RE-11. With the A052s I could wait a little longer. Pretty cool.
- Steve
'70 Tangerine 911T
'86 Guards Red 911
'57 Black MGA
Old 10-15-2019, 07:56 AM
Kraftwerk's Avatar
I was just in Belgium in April, ( April.. i know) and it rained every 45 min for 10 min. so I would go with a tire that can handle a bit of wet..
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 10-15-2019, 10:08 AM
a.k.a. G-man
Geronimo '74's Avatar
True, rain is never far away.
My 911 is a garage queen, only sees water when it gets a shower.
Still haven’t decided, R888r or Advan A052. Leaning towards the Yokohama’s.
Got winter season to make up my mind.
Old 10-15-2019, 11:03 AM
Wout_RS's Avatar
Still following this thread
I'm also in the decision betweed the Toyo and the Advan.
I like both for the look, but I think if you get caught in wet condition (Belgium) the Advan is maybe a better choice?
Old 10-16-2019, 10:20 AM
Driver
Noah930's Avatar
I just installed a set of the Toyos, as no one has the Yokos in stock. I think Tire Rack has them (Yokos) backordered for 3 or 4 months. I figured both tires aren't really ideal for the rain, so drive carefully regardless. And living in SoCal, this car doesn't see any rain anyway.
1990 Black 964 C2 Targa
Old 10-16-2019, 10:27 AM
a.k.a. G-man
Are those 7 and 9’s?
Which tire size did you get on the front wheels?
Old 10-16-2019, 11:14 AM
a.k.a. G-man
They probably are.
I don’t know how much better they are in the wet so it’s difficult to decide if it is going to be relevant.
When it rains, my speed drops instantly. No matter what tires I am using. The lack of esp, abs, traction control is enough reason to be careful.
Dry weather grip, rolling noise, handling are more important to me, I guess.
From what I’ve read, they are both good tires and very negative reviews of either are rather rare.
Old 10-16-2019, 11:25 AM
Driver
Noah930's Avatar
Yes, 7s & 9s. I went with stock 930 sizing for my car.
205/55/16 & 245/45/16.
Old 10-16-2019, 08:04 PM
Flojo's Avatar
exactly. that's why I got the new Yoko Neova
Returning from #flaternity6 (Black Forrest) in the rain. Perfect handling, no fear at all.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-17-2019, 01:55 AM
Driver
Noah930's Avatar
Ok, I've got maybe 50 miles on these new R888Rs, so still too early to give any feedback on their grippiness, but people aren't kidding when they comment on the tread noise. It's not noticable at speed, what with the noises from the motor, wind, and transmission. But when coasting with the clutch in, it's like running off-road tires from a lifted 4x4.
Old 10-19-2019, 11:12 PM
Wait till they wear!
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 10-20-2019, 02:51 PM
Mr. Merk's Avatar
Just wanted to update this thread. I ended up cording one of my front R888Rs while driving out in Colorado last week. I just checked and they had 12,000 miles on them! The tire actually had plenty of tread left but corded from camber wear on the right front.
My rears are almost to 6k miles and the right side is into the secondary rubber but still has way more grip than my new Conti Extreme Contacts that I put on the front to get home.
Old 06-03-2020, 01:13 PM
Would you please share the alingment specs , front and rear, and tire size
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 06-03-2020, 04:23 PM
Mr. Merk's Avatar
Originally Posted by icarp View Post
Would you please share the alignment specs , front and rear, and tire size
Ian
It's been a year since I've aligned it. I know the RF had more camber than the LF. I think it was 1.8/2.2. I think I tried to set the rear at 2.5. Don't quote me on that.
Tires are 225/45 & 245/45 on 16x8s & 9s.
Old 06-04-2020, 05:17 AM
FWIW, a small amount of camber by itself shouldn't cause much wear, unless it's coupled with toe.
Negative camber and toe in fight each other in road force, so a lot of both equals rapid inside shoulder wear.
Matt - 84 Carrera
Old 06-04-2020, 05:58 AM
Mr. Merk's Avatar
There's a good chance the toe is out. It's been a hard year
Old 06-04-2020, 06:16 AM
I think I've figured out your wear issue...
Amazing photo.
Matt - 84 Carrera
Old 06-04-2020, 07:33 AM
BFT3.2's Avatar
..Is the TR1 something to consider? they are also available in 215.
You can read my detailed review of the T1R in this thread below, post #17. The short of it, do not buy those tires under any circumstance.
16" tires
*Just realized this thread is a year old but might be useful to anyone else looking at the very limited options of 245 for their 16x9s
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 06-04-2020, 06:52 PM
