How do the A052 compare to those?
SWB 912 - G50 Carrera - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Haven't run them myself, but friends say they're similar to the Rival S but better in the wet and more tolerant of heat.
Matt - 84 Carrera |
Advan AO52
I got a set of Yokohama ADVAN A052 for my '86 Carrera to take to the track.
205/55-16 and 245/45-16 on 7" and 9" rims. Granted, I need more tire in front (this is what I've always used), but i think these had better bite than the RE-11 that I had been using for years. And...... they hardly squealed at all. My Re-11s always squealed weather new or old. It was really strange that for half a day I was perplexed as to what was going on because I was way off. Eventually, I figured out that I wasn't pushing so much as before and thus didn't need to turn the wheel as much (more bite). I was sort of making tiny corrections all the time (first half of the day) because I was turning in too much - that's the way it always was and I was used to it with the RE-11. With the A052s I could wait a little longer. Pretty cool.
- Steve '70 Tangerine 911T '86 Guards Red 911 '57 Black MGA |
I was just in Belgium in April, ( April.. i know) and it rained every 45 min for 10 min. so I would go with a tire that can handle a bit of wet..
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
a.k.a. G-man
True, rain is never far away.
My 911 is a garage queen, only sees water when it gets a shower. Still haven’t decided, R888r or Advan A052. Leaning towards the Yokohama’s. Got winter season to make up my mind.
Сидеть, ложь, Переворачиваться |
Still following this thread
![]() I'm also in the decision betweed the Toyo and the Advan. I like both for the look, but I think if you get caught in wet condition (Belgium) the Advan is maybe a better choice? |
Driver
I just installed a set of the Toyos, as no one has the Yokos in stock. I think Tire Rack has them (Yokos) backordered for 3 or 4 months. I figured both tires aren't really ideal for the rain, so drive carefully regardless. And living in SoCal, this car doesn't see any rain anyway.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
a.k.a. G-man
Are those 7 and 9’s?
Which tire size did you get on the front wheels?
a.k.a. G-man
I don’t know how much better they are in the wet so it’s difficult to decide if it is going to be relevant. When it rains, my speed drops instantly. No matter what tires I am using. The lack of esp, abs, traction control is enough reason to be careful. Dry weather grip, rolling noise, handling are more important to me, I guess. From what I’ve read, they are both good tires and very negative reviews of either are rather rare.
Driver
205/55/16 & 245/45/16.
Returning from #flaternity6 (Black Forrest) in the rain. Perfect handling, no fear at all.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Driver
Ok, I've got maybe 50 miles on these new R888Rs, so still too early to give any feedback on their grippiness, but people aren't kidding when they comment on the tread noise. It's not noticable at speed, what with the noises from the motor, wind, and transmission. But when coasting with the clutch in, it's like running off-road tires from a lifted 4x4.
Wait till they wear!
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Just wanted to update this thread. I ended up cording one of my front R888Rs while driving out in Colorado last week. I just checked and they had 12,000 miles on them! The tire actually had plenty of tread left but corded from camber wear on the right front.
My rears are almost to 6k miles and the right side is into the secondary rubber but still has way more grip than my new Conti Extreme Contacts that I put on the front to get home.
SWB 912 - G50 Carrera - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com Last edited by Mr. Merk; 06-03-2020 at 12:32 PM.. |
Thanks Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Tires are 225/45 & 245/45 on 16x8s & 9s. ![]()
FWIW, a small amount of camber by itself shouldn't cause much wear, unless it's coupled with toe.
Negative camber and toe in fight each other in road force, so a lot of both equals rapid inside shoulder wear.
Matt - 84 Carrera |
I think I've figured out your wear issue...
![]() Amazing photo.
Matt - 84 Carrera |
16" tires *Just realized this thread is a year old but might be useful to anyone else looking at the very limited options of 245 for their 16x9s
______________ '88 911 Coupe '98 Spec Boxster '85 380SL Benz -Euro Last edited by BFT3.2; 06-04-2020 at 05:55 PM.. |
