Just how old is the 911 fuse design? 1939 at least
Type 64 build in 1939
See the fuse box at 11:53 Dang ! ![]() upload pics https://youtu.be/HaDWPBco07w?t=714
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 08-22-2019 at 03:37 PM.. |
Functionista
And many cars besides Porsche still using the original design 50 or more years later. Why mess with a good thing?
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
And the problem is?
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
Where to start?
Well, let's see........ small contact area of fuse to holder, builds corrosion which causes heat which causes holder failure. Some fuse sizes are getting hard to find. And, last but not least, old fuse holders such as found on Porsches tend to create electrical gremlins that can come and go driving the owner/mechanic crazy trying to track them down. A good solution is to replace the old VW style fuses with an updated panel that uses ATO/ATC type fuses like this.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Mercedes used that design of fuse as well. Many German car makers have used it.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
disband
shug hates these cars... they drive like dump trucks apparently..
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Functionista
Who said problem?
I think it's awesome to be driving a car with 1930s technology in it! VINTAGE
1986 Bosch Icon Wipers coupe. |
AutoBahned
I heard that Ben Franklin used that same fuse holder on the ladies in Paris
Question.............
"To each his own!" In the case of my car, the original fuse blocks needed to be replaced. Rather than spending a couple hundred bucks on new blocks, I made the panel that uses the modern fuses for around a hundred dollars. The electrics have worked great ever since! Over a period of about 10 years I made several hundred of these panels for other disgruntled enthusiasts! Not everyone likes to have to "fiddle" with a car's electrics very often!
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Functionista
Brass legs on fuses and brass posts on fuse block provides no issues with dissimilar metals or galvanic corrosion.
I guess it's a case of YMMV. I've had my 69 for 18 yrs., and changed out one front fuse box due to a buss bar problem on the box. Other than that, never an issue. I've had my 72 for 14 yrs., and never a problem. Both run original boxes.
Mine were some sort of pot metal silver in color.....
Functionista
Hard to know if you are getting the OE fuse type without holding it in your hand before you buy.
