sugarwood's Avatar
Just how old is the 911 fuse design? 1939 at least
Type 64 build in 1939
See the fuse box at 11:53
Dang !
fuse
upload pics
https://youtu.be/HaDWPBco07w?t=714
1986 Bosch Icon Wipers coupe.
Old 08-22-2019, 02:53 PM
Functionista
manbridge 74's Avatar
And many cars besides Porsche still using the original design 50 or more years later. Why mess with a good thing?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-22-2019, 03:24 PM
And the problem is?
Dave
1969 911T Coupe
1972 911E Targa
Old 08-22-2019, 06:42 PM
fred cook's Avatar
Where to start?
Originally Posted by dafischer View Post
And the problem is?
Well, let's see........ small contact area of fuse to holder, builds corrosion which causes heat which causes holder failure. Some fuse sizes are getting hard to find. And, last but not least, old fuse holders such as found on Porsches tend to create electrical gremlins that can come and go driving the owner/mechanic crazy trying to track them down. A good solution is to replace the old VW style fuses with an updated panel that uses ATO/ATC type fuses like this.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 08-22-2019, 08:00 PM
Mercedes used that design of fuse as well. Many German car makers have used it.
Old 08-22-2019, 08:16 PM
disband
juanbenae's Avatar
And the problem is?
shug hates these cars... they drive like dump trucks apparently..
Old 08-22-2019, 08:39 PM
Functionista
Yeah, with bad maintenance practices many systems will fail on any old car. I see a lot of cars with hood gaskets missing or in horrible shape letting all kinds of weather inside allowing for corrosion. Also, I have seen cheap aluminum fuses, added wiring with no regard for amperage demands, etc. Many fuse boxes out there are working just fine and I see no reason to downgrade mine by “upgrading.”
Jeff
74 911, #3
Old 08-22-2019, 08:43 PM
sugarwood's Avatar
And the problem is?
Who said problem?
I think it's awesome to be driving a car with 1930s technology in it!
VINTAGE
Old 08-25-2019, 04:07 PM
AutoBahned
RWebb's Avatar
I heard that Ben Franklin used that same fuse holder on the ladies in Paris
Old 08-25-2019, 04:11 PM
fred cook's Avatar
Question.............
And the problem is?
"To each his own!" In the case of my car, the original fuse blocks needed to be replaced. Rather than spending a couple hundred bucks on new blocks, I made the panel that uses the modern fuses for around a hundred dollars. The electrics have worked great ever since! Over a period of about 10 years I made several hundred of these panels for other disgruntled enthusiasts! Not everyone likes to have to "fiddle" with a car's electrics very often!
FEC3
Old 08-25-2019, 04:54 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
They work fine until they don't. Dissimilar corrosion issues, my original holder worked fine, right up until it didn't. I found several corrosion welded to the posts requiring sandpaper to remove the debris. I tired of "spinning" the fuses every time, I changed the oil. Replaced the fuse blocks with the CCD units, fuse electrical stuff is last on my list of troubleshooting when chasing minor electrical gremlins.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-26-2019, 09:54 AM
Functionista
Brass legs on fuses and brass posts on fuse block provides no issues with dissimilar metals or galvanic corrosion.
Jeff
74 911, #3
Old 08-26-2019, 10:07 AM
I guess it's a case of YMMV. I've had my 69 for 18 yrs., and changed out one front fuse box due to a buss bar problem on the box. Other than that, never an issue. I've had my 72 for 14 yrs., and never a problem. Both run original boxes.
Dave
1969 911T Coupe
1972 911E Targa
Old 08-26-2019, 06:38 PM
Mine were some sort of pot metal silver in color.....
Old 08-27-2019, 05:54 PM
Functionista
Hard to know if you are getting the OE fuse type without holding it in your hand before you buy.
Jeff
74 911, #3
Old 08-27-2019, 06:57 PM
