Lug Nuts Overtightened and NOW STUCK
Hi All- My local Porsche shop over tightened my lug nuts and I have tried everything to get them off. Heat, breaker bars, shop impact wrenches after heat applied ect.
I finally decided to just get a 19mm saw and drill them off...so i thought. I now have only one nut off, the rest are snapped and there is a little metal left that is holding the wheel to the car. See pics. Any thoughts on how to fix this? Can't believe that paying thousands for brakes a few years ago would have caused so many headaches when i went to go get new tires. |
AutoBahned
call the Service Mgr. there and see what he says
better yet send an Email so you have a record ... |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Nuts.
Sorry,
Don't see pics. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
here are a few pics
Under the radar
I am guessing there is corrosion between the lug and wheel. Did you try liquid wrench, or equivalent?
Northern Motorhead
I recently did something similar on someone's KIA where we were able to drive the studs back in enough to loosen what was left of the nuts ...
Not ideal but if they're aluminium lugnuts it might work , best case scenario is you won't damage the rims as compared to trying to cutt of the remains of the nuts with a dremel ! I used a 4X air riveting gun with a large brass snap connected to a 3/8 air hose with 125 lbs air pressure.
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 Last edited by wildcat077; 09-01-2019 at 12:48 PM.. |
Anti-seize lubricant........
I don’t see any trace of anti-seize lubricant on any of the lug bolts (?). What a nightmare you got there. Be careful not to ruin the wheels. Hope you succeed with minimal damage on that wheel. BTW, how many wheels are stuck?
Tony |
Use the hole saw gently to get rid of the rest. Back off when they are through, then use a sharp point punch to get the remains off the studs. No other choice really. done lots of them, GRRRR.
The 9 Store
Next time, don't go to extraordinary means. Instead, take a pic of the wheel, drive it back to shop, talk to the manager/supervisor/owner, tell them you want it to look just like it did when you dropped it off and let them deal with it. The pics are important in case they screw up the wheel.
All used parts sold as is. |
They’re corroded, not overtightened...
I put on some recently sandblasted and powder coated aluminum lug nuts on, no anti-seize. 6 months later after rain and some car washes, took a huge breaker bar to get them off... Aluminum, steel, and rain, don’t play well together... |
AutoBahned
your local Porsche shop seems unfamiliar with the TSB on lug nuts put out by Porsche
Functionista
I would keep going with the hole saw as you have a remainder of one left to gauge how far to go before contacting wheel. I would even go so far as to put some other lugs on with a 1/8 inch or so distance from remainder and do some slow figure eights, stopping often to check. Everyone seems to think the nut in good condition is going to back off/fail (they won’t). If there is a next time, stop before you get this far!
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Too bad there’s no such thing as a left handed holesaw...
https://www.lowes.com/pd/LENOX-3-4-in-Diamond-Arbored-Hole-Saw/50073333 https://www.homedepot.com/p/Milwaukee-3-4-in-Hole-Dozer-Bi-Metal-Hole-Saw-49-56-9605/202327742 and other sources of course.
1984 911 Coupe |
Ugh. Nightmare! Looks like there is (was?) a factory hole saw tool for this application...
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
anti-seize and they will never be stuck and never fall off.
You don't need their flunkies doing any more damage. Best take your time.
Driver
Anyone ever use the candle wax and lighter trick? I've only seennit on YouTube. Melt some wax and let it drip onto the threads. Supposedly the wax works its way in between the threads and voila, what was stuck is no longer unstuck.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
