Key can be removed without turning off the engine
On my 1987 Carrera I can remove the key without turning off the egine.
Anybody knows what should be done in this case?
Is it the key? Or is it the ignition lock?
Old 09-12-2019, 05:49 AM
Probably the steering lock internal tab is broken and doesn't turn the electrical switch below it.
206 637 4071
Old 09-12-2019, 08:30 AM
IROC's Avatar
Is your key excessively worn? I had an old Toyota 4Runner who's key would do the same thing. Got a new key made (from the key code) and it wouldn't come out.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-12-2019, 09:20 AM
DO you mean the key can be removed without turning off the ignition, or the ignition can be turner off and key removed without turning off the engine?
I assume the former. in this case it is wear of the key and tumblers in the ignition cylinder. you could disassemble the ignition switch and replace the tumblers and or have a key cut to code to reestablish the original tolerances.
Old 09-12-2019, 09:23 AM
New-ish 911SC Targa Owner
pampadori's Avatar
My key also does this. I can remove it while it is in the "ON" position. Car of course continues to run because in these old tractors the key isn't doing too much besides aligning the tumblers.
In my 2005 Mercedes the key is coded to the DME and the VIN digitally. I see nothing wrong with the old fashioned setup but then again I've never had my car stolen.
My key doesn't look too worn either. I suspect something in the ignition lock is worn instead but haven't decided to worry about it yet.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 09-12-2019, 09:40 AM
Operationally it isn't really a problem; till you're out running gravel roads in an old rear wheel drive Corolla, you over cook a corner and end up in someones front yard backwards with the engine stalled, and the key has miraculously jumped out of the ignition and into the abyss of the floorboards, and your trying to find it before the porch lights come on, and the homeowner comes out.
Old 09-12-2019, 11:59 AM
AutoBahned
RWebb's Avatar
wear in the lock - maybe just not worry
but you could test it in all 3 parts of Belgium (esp. des Allemagnes part) and see if it is consistent...
Old 09-13-2019, 11:53 AM
Originally Posted by BelgianCarrera View Post
On my 1987 Carrera I can remove the key without turning off the egine. ?
My 74 did the same. I got used to it and never let it bother me.
Old 09-13-2019, 12:33 PM
bavaria911's Avatar
Heck, I can remove the key while the engine is running down the road. Its been doing it for 33 years now.
No concerns about it.
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 09-13-2019, 04:43 PM
Under the radar
Trackrash's Avatar
A friend of mine locked his keys in his 914. I pulled out my 911 key and opened his door.
I don't know if my friend was happy or upset.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-13-2019, 04:47 PM
