the inside project, almost done
stripped of the sound pad and interior panels.
after almost 3 weeks of grinding, scrapping and adhesive remover i painting the whole inside with silver por 15. i then used whitecote as the finish color. the silver por 15 applied and covered much better than the whitecote and a future project will be to sand the whitecote completely smooth but for now it is ok. i also cut lexan for the back and side windows, hopefully it stays in over 100 mph. the major addition to my original project plan was to remove the sunroof and false ceiling from the car. it was fairly easy and only took me a couple hours to completely cut it out after contemplating how to do it for a couple days. i purchased the fiberglass sunroof panel from tre and will get it mounted this weekend. the project took much longer than i expected and i wonder how long it will take for my hands to stop hurting! the car was around 2250 lbs dry before this project and now i should have fallen into the high 2100 lbs range! i think the next step is removing heat. do i really need heat in socal? the end is near, i hope to have it back on the road for a test drive this weekend!
Jim R Gruppe Member once upon a time when you could run generators in Cambria to fix the cars and hit 150+ mph on the fun run "Alles ist gut" 2011 997 GTS "Orange Pepper Wagon" 2009 Cayenne GTS |
Somewhere in the Midwest
Looking like a serious race car, Jim. Nice work! What brand is your roll bar?
No, you should not need heat in SoCAl...man you guys are killing me. I'm praying for just 40+ degrees and no precip this weekend!
Really nice work, Jim. The bare interior looks remarkably nice in white.
Warren & Ron, may you rest in Peace. |
It's starting to look serious. Can't wait to see it.
The black / white / red combo looks sharp too. Where have I seen that before..... Oh yea.
Chuck Moreland - elephantracing.com - vonnen.com |
Chuck, I thought you were going to show this...
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
nice looking job. my latent apathy is motivated by your project.
how many quarts of por15 did it take to complete the interior? did you use their primer and metal etch?
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
thanks all!
i used the marine clean and the metal etch. i did not take the car completely to bare metal and the prep process worked very good. although about 70% was all the way to bare metal once i used a wire cup to remove the seam sealer. for the silver, base coat, i purchased the 6, 4 oz pack and used 5 of them for the whole interior including the roof. this included 2 coats. i used 2 quarts of whitecote in about 4-5 coats to get it to cover. if i were doing it again i would not have used whitecote and/or i would have sprayed the final color. still it is reasonable but i will sand it smooth in the future and respray the interior once i forget how much work it has been. it is funny, i did not really plan for a red, black and white color scheme but since my new bbs wheels are red and i have some white fiberglass panels on the car and i wanted a lighter color on the inside to help repell heat the red, black and white scheme just sort of happened. although the elephant racing logo that has been on the side of my car could of had a subconcious influence. ultimately, i really like it. can't wait to get it back on the road and ultimately to the track as the suspension has also been reworked including new tbars, sway bars, and corner balance. should help remove seconds from my lap times at the next poc sts event april 12-13.
thanks for the info. good luck in your lightened ride.
Looks great. I did less than that to my BMW and it took FOREVER. Congratulations on sticking at it.
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
jim
looks good. gary
1975 911S Targa Silver Anniversary Edition |
Jim, the car looks great. Be sure to drop me an email when you get the car back up to Newport. I definately want to come check it out.
Very impressive bit of work. Looks great!
Keitho64 05 GTO 00 911 C2 64 Corvair Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles |
one of gods prototypes
looks great
a job well done
Brought to you by Carl's Jr. |
Warren Hall Student
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
