Question Flag Style Mirror Disassembly
Has anyone ever taken apart a flag style mirror for a 76 - 86 911? I am in the process of prepping my car for paint and cannot figure out how the thing comes apart. I did a search and someone said there some sort of plastic ring behind the mirror that needed to be turned. When I move the mirror, all I see is a rubber boot covering the motor.
Any help would be greatly appreciated.
-Dave
Old 03-27-2003, 01:40 PM
Don't do this until comfirmed....I believe the mirror glass has to be gently pulled/pried off. There are 2(or is it 4?) metal nipples on the back of the glass that are inserted into the motor mount. After the glass is off you have access to all.
I'm going by memory and I haven't done this in about 6 years.
Warren & Ron, may you rest in Peace.
Old 03-27-2003, 01:46 PM
Heck, I’m only 5 not 71!
targa80's Avatar
The mirror is held in place by four clips to the motor frame. Using a thin putty knife/scraper slide it in behind the mirror to pry the mirror off. Be careful of the mirror heating element sandwiched between glass and the mirror glass.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 03-27-2003, 01:57 PM
Senior Member
Is the rubber ring surrounding the glass replaceable? My drivers side one is slightly warped and I would like to replace it
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 03-27-2003, 02:31 PM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
Hi osidak, The rubber trim on the mirrors is replaceable.. but, it's not seperate from the servo motors. so basically you have to replace the entire mechanism.. Not cheap either if you want new ..I'm sure you can find a used one.
Jorge (Targa Dude)
Old 03-27-2003, 02:44 PM
Silveresrty911S's Avatar
I just did mine and there are 3 clips holding the mirror to the metal part with the rubber trim and servos, the mirror is not a seperate piece to the heating element that has 2-wires attached.
Once the mirror is out, there will be 3 screws holding the metal/rubber/servo part to the flag part of the mirror, unscrew those and seperate the electrical connector and it comes right out.
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 03-27-2003, 03:36 PM
You will also need a special tool to remove the wire from the connector You can make the tool yourself. I can't remember the dimensions of the tool. E-mail me if you can't figure it out.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-27-2003, 06:46 PM
Senior Member
thanks
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 03-27-2003, 07:12 PM
ruf-porsche's Avatar
I brought the tools from performance part. You need it to take the mirror off the car without resorting to cutting and splicing the wires.
Old 03-27-2003, 07:32 PM
pkfrdh's Avatar
Porsche Crest Mirror removal from early style flag mirrors...be careful!
The tangs on the back of the early style mirrors are easy to break off! They have to be coaxed off a little at a time w/ the pressure at the base of the tang...don't press on the glass! The tangs are pressed into plastic lined holes...a fair amount of pressure holds them in...tangs break off!
I have a spare left side mirror setup I can sell spare parts from in case you need the tangs or the motor unit with a good rubber component attached.
Contact Joe in Santa Barbara at : jglsbca@juno.com
Pictures of the mirror off of the early style :
Picture of the spare mirror I have that I can sell spare parts off of if you need any :
(It is the one on the left. It has a mirror defect in the glass...otherwise it is perfect and has great condition spare parts...the other mirror is sold)
Old 03-27-2003, 07:36 PM
Senior Member
I would be interested in the rubber ring how much do you want for it
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 03-27-2003, 07:46 PM
pkfrdh's Avatar
Porsche Crest Rubber ring is attached to motor unit...
The rubber "ring" is attached to the motor unit...it is cast around it and is not separable. Sorry...if you need a new rubber trim for a mirror, the only way is to replace the motor unit too.
The motor units are available new for about $230 for the early style ('76 to '86) and $180 for the later style ('87 to '91).
I can sell my good working early style motor unit with nice rubber trim for $60 + shp.
Contact Joe in Santa jglsbca@juno.com
Old 03-27-2003, 08:31 PM
Thanks to all for the info and the pictures!! I'll give it a try this evening and let you all know if I run into any problems.
-Dave
Old 03-28-2003, 06:22 AM
From the looks of pkfrdh's picture it look like someone didn't buy the special tool to remove the wires from the connector. The blue crimps are a give away and the fact that the connector is not on any of the mirrors.
Old 03-29-2003, 08:37 PM
Cool
Hey ruf.. I couldn't find the tool in the catalog.......... Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-29-2003, 08:54 PM
